- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
- Report Inappropriate Content
Set Editiable rows with formula column
Hello guys,
i am trying to create a datatble with user restricted rows and columns. I have a default value column ( its default value for all column values in that row) i have coded this as formula in other columns ... but i am not able to have user input if i have formula ... i need flexibility for user to enter data
n = 10;
rownList = {};
For(i=1, i<=n, i++,
Insert Into(rownList, "Row " || Char(i));
dt = New Table("Restricted Row Value Table",
Add Rows(n),
New Column( "Row Number",Character,"Nominal",Set Values(rownList),Color Cells( {77, {0}} ))
dt << New Column("Default Row State","Nominal",Color Cells( {-14803425, {0}} ));
For(i=1, i<=n, i++,
dt << New Column("Column " || Char(i),"Nominal",
Formula( If( Is Empty( :Default Row State ), Empty(), :Default Row State ) )
dt << Set Edit Lock( "Add Rows", "Add Columns", "Delete Columns" );
how do i rewite formula such that it allows user input but takes default value if specified ... kindly guide... Thanks in advance
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Set Editiable rows with formula column
This method for you might work. Use a hidden column that has a formula that sets the value in a different column. The column that has the value set remains editable, since it does not contain a column formula.
New Table( "Examplel",
Add Rows( 10 ),
New Column( "Default Row State",
Numeric,
"Continuous",
Format( "Best", 12 ),
Set Values( [., 3, ., ., 44, ., 8, ., ., .] )
New Column( "formula column",
Numeric,
"Continuous",
Formula(
If( Is Empty( :Default Row State ) & :Default Row State != :Formula Column,
:Output Column[Row()] = .,
:Output Column[Row()] = :Default Row State
:Formula Column = :Default Row State;
Hide
New Column( "Output Column",
Numeric,
"Continuous",
Set Values( [., 3, ., ., 888, ., 8, ., ., .] )
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Change
from a Formula() to Set Each Value()
Set Each Value( If( Is Empty( :Default Row State ), Empty(), :Default Row State ) )
and the column will have real values rather than a formula, thus allowing for editing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
@txnelson Thanks for reply ... But set each value() is not dynamic...
when user enters data in "default row value" it applies to all others but doesnt allow any user input to that column,
is applied only during the first execution ...
is there any way formula can accomodate user input?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Add Rows( 10 ),
Numeric,
"Continuous",
Numeric,
"Continuous",
Formula(
Hide
Numeric,
"Continuous",
