tajrida
Separate number and character in cell
I have a column in given format, Is it possible to remove the “hr.” from the cells and just leave the  numbers?
1.2 hrs
1.6 hrs
4.5 hrs
7.6 hrs
8.2 hrs
1.0 hrs
0.9 hrs
The output I desire is:
1.2
1.6
4.5
7.6
8.2
1.0
0.9
Mohammed Ahmed
stan_koprowski
Re: Separate number and character in cell
There are several ways to do this depending on the version of JMP you are using and how you would like to approach it.
One way would be to create new column and add a formula as follows:
9224_Screen Shot 2015-07-14 at 8.53.34 PM.png9224_Screen Shot 2015-07-14 at 8.53.34 PM.png
Or if you are using JMP version 12 you could use Text to Columns utilities as follows:
1. Select the column you would like to convert and the select the option under the utilities menu.
2. Put your delimiter in as a space (" "):
3. This will give you the following output:
9223_Screen Shot 2015-07-14 at 9.01.00 PM.png9223_Screen Shot 2015-07-14 at 9.01.00 PM.png
Others might have more creative approaches.
Best,
Stan
stan_koprowski
Best,
Stan
