Thomas1
Level V
Select specific columns with JSL name contains code
The Name contains script:
New Window( "Filter Col Selector Example",
    fontobj = lb = Filter Col Selector( width( 250 ) )
lb << Name contains( "a" );
delviers all colums, which contains a. What code must be added in order to mark one of these columns by clicking or double clikking the column from the list box?
23 REPLIES 23
Thomas1
Level V
Re: Select specific columns with JSL name contains code
Perfect!
Now the JSL is working as it was intended. This makes things much easier. Thanks again.
Very good exmple. Could you also have similar jsl for row selector for a column?
Thanks
ram
Also, can we do similar filter for the items in a list? Thanks Ram
gzmorgan0
@ram_asra_gmail_, this link is to post that describes building a ListBox search and selection interface.  While some of the discussion uses the JMP Class object which is avaialable in JMP14, the first post descrbes teh interface using functions: it works on JMP 13.
See  https://community.jmp.com/t5/Discussions/Can-a-scripted-quot-widget-quot-be-converted-to-a-Class/m-...
The files attached to the original post ( TEB_LB_Widget.JSL,  TestTEBSelector.jsl,   TestLBFilter.jsl) are explained in the post with screen shots.
