Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMP® Marketplace
Thomas1
Level V
Select specific columns with JSL name contains code
The Name contains script:
New Window( "Filter Col Selector Example",
    fontobj = lb = Filter Col Selector( width( 250 ) )
lb << Name contains( "a" );
delviers all colums, which contains a. What code must be added in order to mark one of these columns by clicking or double clikking the column from the list box?
3 ACCEPTED SOLUTIONS
ian_jmp
Level X
Re: Select specific columns with JSL name contains code
Not sure I have understood correctly, but is this what you are after?
// Make a FilterBoxSelector
New Window( "Filter Col Selector Example", lb = Filter Col Selector( width( 250 ) ));
// Define and set an 'action' script
actionScript =
Expr(
	selected = lb << getSelected;
	dt << clearColumnSelection;
	dt << selectColumns(selected);
lb << setScript(actionScript);
// Try it out
lb << Name contains("sex");
Wait(3);
lb << Name contains("eight");
gzmorgan0
This script works in JMP 12 and JMP 13. The reason the previous script does not work in earlier versions of JMP is that the data table messages clear column selections and select columns(list)  are not available. In earlier versions, columns need to be selected and unselected one at a time, hence, the required changes below. I do not have access to any version earlier than JMP 12.
    fcb = Filter Col Selector( width( 250 ))
ib = (fcb<<Parent) << Xpath("//IfBox");
ib << set(1);
lbb = (fcb<<Parent) << Xpath("(//ListBoxBox)[1]");
lbb << set Function(Function({this},{_xx, i},
   selCol = this<<get selected;
   _xx = dt << get selected columns;
   For(i=1, i<=nitems(_xx), i++, _xx[i] << set selected(0));
   For(i=1, i<=nitems(selCol), i++, column(dt,selCol[i] ) << set selected(1));
Thomas1
Level V
Perfect!
Now the JSL is working as it was intended. This makes things much easier. Thanks again.
23 REPLIES 23
gzmorgan0
Try this
//select name
_xx = lb << get items;
_idx = Contains(_xx, "name");
lb << set selected( _idx, 1);  //or 0 to unselect
To see the available messages for an object select Main Menu > Scripting Index > Display Box > FilterColSelector
Thomas1
Level V
Thanks for your reply. Unfortunately, I did not get the results with the JSL update. Right now, I do not know why.
What I actually want is to get a similar behavior like for Cols / Columns Viewer ... / Name Contains … in JMP.
In general, this is possible with the mentioned JSL code from the Scripting Index:
lb << Name contains( );
However after the search string has been run, I I’d like to mark the desired / selected column in the data table, by double click. This part is still missing or not working within the JSL code from the Scripting Index.
ian_jmp
Level X
actionScript =
Expr(
// Try it out
Wait(3);
gzmorgan0
Ian,
This is somewhat of a related question. Since the blogger response  had lb<< Name Contains(), I assumed, the request is for the user to enter a filter field and all columns would be selected.
So I tried to expose the Filter field (Show Filter). I failed at multiple attempts to enable this second menu item via JSL.
Is there a method to enable the filter field and configure the filter? I can get the PopupBox Menu Count, and Menu Text, but not the selection.
gzmorgan0
Figured it out:
    fcb = Filter Col Selector( width( 250 ) )
ib << set(1);
Thomas1
Level V
Am I missing something. I can't get to selected column in the data table.
Thomas1
Level V
Thanks for your support Ian. It is not yet working as I want.
I' m looking for JSL code with which I can general search for specific columns by name ( part1) and then select the desired column in the list box from part1 by double clicking and mark the column in the data table.
The general search part1 is done with JSL code:
dt = Current Data Table();
New Window( "Column Search",
The marking part2 could be done for the example like the code from the scripting index
dt = Open( "$SAMPLE_DATA/Blood Pressure.jmp" );
dt << Go to( :BP 12F );
 How must they combined in order to find, mark and  go to the columns in a data table?
gzmorgan0
Try this
ib << set(1);
   dt<<clear Column Selection;
   dt <<select Columns(selCol) ));
Thomas1
Level V
Thanks for your endurance. I really appreciate it. However the JSL is still not working as intended (see image).
The goal is to get the same function as one gets by using Cols /  Columns Viewer / Name  Contains. The results, which are being shown in the search box, can be clicked and as result, the specific column is selected in the origin data table.
 In case the proper JSL code is available, the whole column search / select process can be carried out much faster.
