ab0716
Select rows based on first character
Hi I have a column with a lot of numbers and some text. Below is a snipet of what my data looks like. I'm tring to hide and exclude all rows that aren't 7 digits long and don't start with 5 (i.e. I only want numbers like 5******).
5238403
5236577
3238403
ASKU
523660682
asku
2536614
NI
5236610
So far I know how to exclude all the rows that aren't 7 characters long, but I can't figure out how to select the rows that don't begin with 5 (e.g. 2536614).
dt<<select where(length(:column) != 7 );
dt<< hide and exclude (1);
ab0716
Re: Select rows based on first character
For some reason that solution still left a few numbers that didn't fit my criteria, but when I split it up as two separate lines it works great! Thanks!
dt <<select where(left(:column, 1) != "5" );
dt <<select where(length(:column) != 7, current selection("extend") );
vince_faller
dt<<select where(length(:column) != 7 & left(:Column, 1) != "5");
Vince Faller - Predictum
ab0716
gzmorgan0
If the lot number must be 7 numeric digits, what begins with 5, one more condition needsto be added.
dt = current data table();
dt<<select where(length(:Column 1) != 7 | left(:Column 1, 1) != "5" | IsMissing(num(:Column 1)));
Also, new column using a formula can find matches using Regex. Column 2 of the table displayed below, uses the formula
 Regex( :Column 1, "(5\d{6}\b)", "\0" ). the selected rows are those selected by the Select Where() command above.
Note row 10, 5Z3661A, would not be selected without the additional criteria IsMissing(num(:Column 1))
