Yngeinstn
Level V
How to loop using a function
The difference between Function() and Expr(). After msharp answered my question yesterday, i realized that i have been doing this all wrong. Currently every output whether it is a Graph Plot or Distribution had its own individual Expr() with 3 different iterations inside of it. In a nutshell, that is ~ 20 Expr() scripts. The ability to use a Function would cut that down to one graph plot script and one distribution script. What i am having difficulty doing is now looping through the function.
I have attached the sample data table, a sample of just one of the expressions i use to graph plot and the start of a function script. I would apprecaite any help in solving this problem. I can use the solution to this problem and apply to many others. You can run the original script to understand what i am trying to do..
Thank you
P.S if you have the time i am trying to combine the 3 journals into a single journal. I am trying to back into a script that posted on this thread
https://community.jmp.com/t5/Discussions/Combine-multiple-journals-into-one-journal/td-p/6129
Re: How to loop using a function
First off, if you are going to pursue JSL coding, you need to thourthly read the Scripting Guide
     Help==>Books==>Scripting Guide
Below is a reworking of your script to illustrate how to loop using a function and how to keep all of the output in the same output journal.  I know it is not exactly what you need, but it should give you a good start on how to do what you want
dt = Current Data Table();
doGraphPlot = Function(
	{dt, Xaxis, Yaxis, Grby, chnl},
	Eval(
		Substitute(
				Expr(
					gb = dt << Graph Builder(
						invisible,
						where( dt:Channel == __chnl__ ),
						size( 600, 400 ),
						show control panel( 0 ),
						variables(
							Y( Eval( Yaxis ) ),
							X( Eval( Xaxis ) ),
							Group X( Eval( Xgrby ) ),
							Overlay( :RowCol )
						elements( smoother( X, Y, legend( 19 ), lambda( 0.0001 ) ) )
			Expr( __chnl__ ), chnl
	Report( gb )[Outline Box( 1 )] << set title( "Channel = " || Char( chnl ) );
jjrn = New Window( "Data Plot - Output_1 vs Input", <<Journal );
dtsum = dt << Summary( Group( :Channel ), invisible ); //
Yaxis = Expr(
	Column( dt, "Output_1" )
Xaxis = Expr( Column( dt, "Input" ) );
Xgrby = Expr(
	Column( dt, "wafer_number" )
For( i = 1, i <= N Row( dtsum ), i++,
	chnl = dtsum:Channel[i];
	doGraphPlot( dt, Yaxis, Xaxis, Xgrby, chnl );
	jjrn << append( Report( gb ) );
	gb << close window;
Yaxis = Expr(
	Column( dt, "Output_3" )
Xgrby = Expr(
	gb << close window;
Close( dtsum, nosave );
	Eval(
		Substitute(
				Expr(
						invisible,
						size( 600, 400 ),
						variables(
							Y( Eval( Yaxis ) ),
							X( Eval( Xaxis ) ),
							Overlay( :RowCol )
Yaxis = Expr(
Xgrby = Expr(
	gb << close window;
Yaxis = Expr(
Xgrby = Expr(
	gb << close window;
Yngeinstn
Level V
Thank you Mr. Nelson,
I really appreciate the help you and the community provides. I must tell you that coding in general is very new and hard for me. You are talking to a person who got a 'C' in C++ and ran with it. For every hour that i spend coding, I spend 3 hours reading the Scripting Guide, using the Scripting Index and of course reading through the forums. Due to my ignorance with coding in general and then trying to translate that into JSL, I spend a significant amount of time on my own time learning. I am usual spending my time reading code that was posted here and try to back into with what i am trying to do. I am signing up for the webinars to learn more and espically get a handle on JMP 14 when it rolls out in the very near future. I apologize if i am asking too many questions and seeking help more than any other individuals.
With that said, thanks again for your help.
