rverma
Select middle 90% range using quantiles
I have a Numeric Continuous column labeled as Height with several hundred height values. I want to exclude outliers by just using the middle 90% range of data. I am trying to script it in JSL by selecting all rows below 5% quantile and above 95% quantile and then exclude them. But I am not able to make it work by using script below. I will appreciate any guidance.
RowsBelow5PCTL = dt << get rows where( :HEIGHT < Col Quantile( :HEIGHT, .05 ) );
RowsAbove95PCTL = dt << get rows where( :HEIGHT > Col Quantile( :HEIGHT, .95 ) );
Re: Select middle 90% range using quantiles
I believe this will give you what you want;
dt << select where(
	:HEIGHT < Col Quantile( :Height, .05 ) |
	:HEIGHT > Col Quantile( :Height, .95 )
dt << exclude;
Or if you need to have your above and below row number matrices, then this will work
dt << select rows(RowsBelow5PCTL);
dt << select rows(RowsAbove95PCTL);
dt << exclude;
dt << select where(
dt << exclude;
dt << exclude;
rverma
Thank you very much.
