shasheminassab
Select/ deselet all checkboxes
Is there an easy way to select/deselect all check boxes in legend setting instead of doing them one by one? See attached.
Thanks,
gzmorgan0
Re: Select/ deselet all checkboxes
Click on the first check box. Holding the SHIFT key click on the last check box.  Right click and select Toggle check box
gzmorgan0
shasheminassab
Wonderful! thanks.
