Created:
Aug 6, 2018 03:55 AM
| Last Modified: Aug 6, 2018 12:56 AM(11257 views)
Hi All,
I have 3 columns as shown. For some reasons, I am using formula to concatenate the Mth/Day and the end result is shown in column3. I would like to know how can I exclude cells(using script) that contain 01Jan1904 as I do no need them.
Thanks. I actually intended to exclude those data for Column 3 as in actual case, I have other columns of data (from same rows)that may be useful. I tried with dt << Exclude rows(xx); but does not seems to work. Any suggestion :)
