Onjai
Searching and counting substrings within a text field
JMP Add-in did a great job importing hundreds of MSWord documents into a table.
I have a column called "comment (original)" that I wish to count the number of "no comment" phrases.
When I use the formula,
N Rows(
Loc(
Words( :"comment (white space collapsed)"n, " " ),
"comments"
it returns the number of occurrences for the term "comments".  However, the Loc function will not accept "no comments" as an argument.
N Rows(
	Loc(
		"comments"
JMP v17.1
Interestingly, the formula works correctly if the comment column was recoded to collapse whitespace.  Not sure why.
Any thoughts or assistance would be appreciated!
Thank you.
Re: Searching and counting substrings within a text field
If you want to use Loc, you have to figure out other way of splitting the string into a list than Words(). With Words() you won't get "no comments" string in the list as those will be split into "no" and "comments.
One option would be to substitute all "no comments" with empty strings, then compare length of the original and new string and divide with the length of comparison string. Something like this might work:
str = "Friday, December 9, 2022 10/19/2022 9:37 AM flagged with a comment 10/21/2022 6:15PM : no comment 11/15/2022 1:03 PM 3: no comments 11/16/2022 11:06 AM 4: no comments 11/18/2022 2:49 PM : no comments 11/30/2022 3:52 PM : comments 12/09/2022 9:07 AM : no comment";
str_to_search = "no comment";
new_str = Substitute(str, str_to_search, "");
matches = (Length(str) - Length(new_str)) / Length(str_to_search);
Onjai
Interesting approach.  Thank you.
When I ran the script, it returned a count of 5.  Three (3) of the cases are "no comments" and two (2) are "no comment".
Not sure if or how the Substitute function allowed the plural? i.e. str_to_search = "no comment".   Also the Length function would have been 1 more for the plural "no comments".
I am curious to know if there is another approach to validate this?
I expected that no comment and no comments would be the same and because no comment is in both of those, the replacement will work (for no comments it will just leave the s there). If you need more complex replacements Regex would be a good option while using GLOBALREPLACE.
Onjai
Got it.  I saw that in the script when hovering over the variables.  This works.  The only issue is that it is case sensitive.
I may run this as a column formula.  Adding 2 more columns for the case types and sum the columns by row.
(Length( :"comment (white space collapsed)"n ) - Length(
	Substitute( :"comment (white space collapsed)"n, "no comment", "" )
)) / Length( "no comment" )
Thank you.  I'm back in business.
Cheers
Onjai.
Substitute does allow you to use << IGNORECASE
Substitute("Apple,APPLE,apple", "apple", "orange", <<IGNORECASE);
https://www.jmp.com/support/help/en/17.0/#page/jmp/list-functions.shtml?os=win&source=application#ww...
