Try the Materials Informatics Toolkit, which is designed to easily handle SMILES data. This and other helpful add-ins are available in the JMPĀ® Marketplace
vishwasanj
Searching a value in a column- JSL
Hi All,
Can anyone help me with the search for a particular value in a column and try to find the count of that value with the overall count? In the below example, I am trying to search for value "1" in B column. I found 3 occurences in 10 instances so C is marked with 30%. Similarly for A=2, I found 4 occurence of "1" in 12 instances, so C is marked with 33%.
ABC
1130%
187
190
165
11
165
13
11
134
15
2133%
25
22
247
21
254
21
285
21
21
222
221
Thank you
Re: Searching a value in a column- JSL
I think this should work:
col number(:b, :a, :b )/col number(:b, :a)
You need to take a look at the documentation on Col Number() in the Scripting Index
     Help==>Scripting Index==>Col Number
10 REPLIES 10
You can use the Tabulate Platform and specify the % Column Total as the statistic.
You can also create a new column and use the following formula to get the answer
Col Number( :b, :b ) / Col Number( :b )
vishwasanj
Thank you txnelson. What is :b represent? I am sorry , still new to this idea. I tried Tabulate also, I don't really understand the syntax which i should use as a grouping column?
:b represents column "b", from the data table you listed in the original question.  The formula,
     Col Number( :b, :b) / Col Num( :b )
is interpreted as:
the count of all of the values in column b, for the current rows value of column b, divided by the total count of the values for column b.
In the example data you provided, the calculation for the first row would be:
   The count of values found in column b, that match the value for column b.  That is, the value of the first row for column b is "1", so it would count the number of "1"s found in column b, which is 8.  It would then divide by the total number of the values found in column b, which is 22.
Concerning the Tabulate Platform, what you would do, is to change the modeling type of column b to Nominal, so Tabulate will treat the column as a grouping column.  Then you would drag column b to the Drop Zone for Rows.  I will then list out each of the values found for column b.  By default, the statistic column that is listed is the count(N).  To change it to the Column %, you would just drag the Column % statistic to the "N" column, and it would replace the statistic with the column %
vishwasanj
Thank you for the quick solution. Is there a way to segregate by column A. For example, instead of taking all 7 1's and 22 values together, can we do it by column A (10, 12) and getting the corresponding column % statistic?
Thanks.
vishwasanj
Wow. This is amazing. Thank you txnelson
DC1123
HI
I checked the Col Number. Is this what you mean? but it won't work.
Col Number( :height,:height )/Col Num( :height )
you misspelled "col number()" as "col num()"
dt << New Column( "thepercent",
	formula( Col Number( :height, :height ) / Col Number( :height ) )
vishwasanj
Is there a way not to duplicate the values? As in, every 1's will be corresponding to the %. If I have multiple 1's in the each 1 will have 30% next to it. Can I make it appear once per Group A just like my example above? Helps me in the plotting and subsequent analysis.
