Jackie_
Searching Maximum value of each row across several column and name of source column
I'm trying to come up with a jsl script which can find max value of each row and the column name corresponding to the max value. I was able to find the max value across all the columns but need some advice to find the column name corresponding to the max value
Here's the code:
dt = Current Data Table();
dt << Select Columns( 2 :: 14 );
col = dt << Get Selected Columns( );
val = dt:MaxVal << get values( Format( "Best", 12 ) );
dt:Maximum Value << Set Formula( Max(col) );
nc = (N Items( col ));
For( j = 1, j <= N Items( val ), j++,
	xxx = {};
	For( i = 1, i <= nc, i++,
		If( Contains( char(col[i]), val[j] ),
			Insert Into( xxx, char(col[i]) )
	Column( dt, 16 )[j] =  xxx;
Re: Searching Maximum value of each row across several column and name of source column
There are many ways of doing this. Below is one example which should get you what you need:
dt = Open("$DOWNLOADS/Sample data.jmp");
col_names = (dt << Get Column Names("String"))[2::(N Cols() - 2)];
m = dt[0, col_names];
Column(dt, "Maximum Value") << Set Values(V Max(m`));
Column(dt, "Maximum Col Name") << Set Data Type("Character");
Column(dt, "Maximum Col Name") << Set Each Value(
	max_idx = Loc(m[Row(), 0], :Maximum value)[1];
	col_names[max_idx];
Edit: Copy pasted correct script
Edit2: Second quite similar option:
Column(dt, "Maximum Value") << Set Each Value(Max(dt[Row(), col_names]));
	// could use loc max, but as we need maximum value in column, we can just use that with Loc
	max_idx = Loc(dt[Row(), col_names], :Maximum value)[1];
	col_names[max_idx];
Here is another way of solving the problem
dt << new column("MaxVal", set each value(Max(col)));
dt << new column("MaxVal Column", character, set each value(char(col[loc(matrix(col),:MaxVal)[1]])));
6 REPLIES 6
	col_names[max_idx];
	col_names[max_idx];
Jackie_
@jthi Thanks. Your code finds max value across column it seems and I want to evaluate max value of each row across multiple columns. I am expecting the following results
I had copy-pasted some very weird script, I have now edited it to correct one
dt << new column("MaxVal Column", character, set each value(char( col[loc(As List(matrix(col)),:MaxVal)[1] ])));
Propose above correction to last line for JMP14 atleast: the matrix(col) returns a matrix and the loc function needs a list as first argument so the matrix needs to be converted into a list with "As list".
markschahl
Thanks for this Jim! Just used this on 250 columns. Hope you are doing well.
I am now a long way from Texas. Map.
