PoissonGopher92
Optimization with factor constraints
So I want to perform an optimization but I want to include constraints of the factor combinations possible, from which the optimum should be found. So I want T1, T2, T3 as well as D1, D2, D3 to be varied at the same time. So all factors containing T should have the same level and all factors containing D should have the same level at the end of the optimization. So in a sense, the respective factors should be tied together for the optimization (T1 = T2 = T3, D1 = D2 = D3). Sadly I did not find how to do this in JMP. Any help is welcome!
MathStatChem
Re: Optimization with factor constraints
Create a two new columns in the data table, T and D.   Copy the prediction formula of the model and replace T1, T2, T3 in the model with T, and D1, D2, D3 in the model with D.  The profiler that function and find the optimal setting for T and D.
MathStatChem
PoissonGopher92
Works perfectly, thank you very much!
