Jackie_
Search where
I want to select all rows containing value > 5. In the following script I used for, if and contain statement to select columns containing string "SE" and to highlight row containing values > 5 from the selected column I used the select where( Row() > 5) but doesn't work.
Clear Globals();
Clear log();
dt = Open("$SAMPLE_DATA/Water Treatment.jmp");
dt << Clear Column Selection();
Col_List = dt << Get Column Names("String");
for(u = 1, u <= N Items(Col_List),u++,
If(Contains(Col_List[u], "SE"),
 Column(Col_List[u]) << Set Selected(1);
dt << Select where( Row() > 5);
Jackie_
Re: Search where
It worked
Clear Globals();
Clear log();
list = {};
If(Contains(Col_List[u], "ZN"),
Column(Col_List[u]) << Set Selected (1);
	Insert Into(list, Col_List[u]),
dt << Select where(as column(list) > 5 );
Re: Search where
is specifying to select all rows, where the row number(row()) is greater than 5.
What you need to do is to replace Row() with the column whos values you want to  select if greater than 5.
Check out the documentation on Select Where() in the Scripting Index.
Jackie_
Re: Search where
Hi @txnelson ,
Still not working. Thoughts?
Clear Globals();
Clear log();
list = {};
If(Contains(Col_List[u], "SED-E"),
dt << Select where(Column(Eval(list)) > 6)
Jackie_
Re: Search where
It worked
Clear Globals();
Clear log();
list = {};
Re: Search where
Your solution will only work if only one column is found when you use the
If you use:
If(Contains(Col_List[u], "SS"),
and set the select to
dt << Select where(as column(list) > 179);
you will see that the rows are selected based upon only the first column in your "list"
