danielrbiber
Scripting the Width of Column Switcher in Graph Builder
I am scripting several visuals with column switchers and am finding that they default to a larger size than I would expect.  I took the example JSL from another similar post Scripting-column-switcher-using-variable  but tried to get change the column switcher width.  I added a local data filter as I know that one can manipulate the sizes of those objects with "Display()".  You may notice that I added this to column switcher below.
Can this be accomplished?
I am asking as users are not able to change this width once posted to JMP Live.
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
col_list3 = dt << get column names( Numeric );
For( i = N Items( col_list3 ), i > 0, i--,
	If( !Contains( col_list3[i], "PN" ),
		Remove From( col_list3, i )
Graph Builder(
	Size( 534, 572 ),
	Variables( X( :PNP1 ), Y( :NPN1 ) ),
	Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) ),
	Local Data Filter(
		Add Filter(
			columns( :lot_id ),
			Display( :lot_id, Size( 178, 221 ), Height( 221 ) )
	Column Switcher(
		:NPN1,
		{:NPN1, :PNP2, :NPN2, :PNP3, :PNP4, :NPN3, :NPN4, :NPN5, :PNP5, :NPN6, :PNP6,
		:PNP7, :NPN7, :PNP8, :PNP9, :NPN8, :NPN9, :NPN10, :PNM1, :NPN11, :PNP10},
		Display( Width( 100 ) )
Re: Scripting the Width of Column Switcher in Graph Builder
I would add the column switcher in a little bit different manner so you can get reference and then use << Set Size to that reference:
gb = dt << Graph Builder(
	Size( 534, 572 ),
	Local Data Filter(
		Add Filter(
			columns( :lot_id ),
colswitcher = gb << Column Switcher(
	:NPN1,
colswitcher << set size(300,300);
You could also check from Right click -> Edit -> Show Properties how to reference Column Switcher that way.
	Size( 534, 572 ),
	Local Data Filter(
		Add Filter(
			columns( :lot_id ),
	:NPN1,
danielrbiber
That did the trick.  Starting to finally wrap my head around how JSL works.
Couple of good ways to see how you can affect things are for example (using gb as example reference):
gb << Show Properties;
gb << Show Tree STructure;
gb  << Get Xml; //use with XPath
Also checking JMP Scripting Guide and using Scripting Index will help a lot.
There are also some excellent topics on element/display manipulation can be found from JMP Community. Couple examples:
Supercharge Your User Interfaces in JSL ( US 2018 113 )
Navigating your reports using XPath
