GroupSquareWolf
Scripting: save multiple data table to multiple sheets in Excel
I like to save multiple datatables, each to an individual sheet, in a single Excel file?
What is the script to achieved that?
I tried "append", but it did not work
dt<< Save as("$DESKTOP/Untitled73.xlsx", append);
Re: Scripting: save multiple data table to multiple sheets in Excel
The answer to your question comes from the Scripting Indes
Here is one of the examples from that entry
Open( "$SAMPLE_DATA/Abrasion.jmp" );
Create Excel Workbook(
	"$TEMP/MyWorkbook.xlsx",
	{"Big Class", "Abrasion"},
	{"Big", "Abrasive"}
This issue you are having is with 2 of the elements that you are attempting to pass to the Create Excel Workbook
The  third element in Create Excell Workbook function, need to be a list.  In your case,  the specification is not a list.
  Element 2 documentation indicates that what is required is "List of open tables".  While your specification of
 While the returned element from the Summarize() function, GroupBy, is a list, GroupBy[1] is a string variable.  You need to do something like
tempList = {};
insert into( tempList, GroupBy[1]);
Create Excel Workbook ("$DESKTOP/Untitled1.xlsx", {dt2}, tempList);
	{"Big", "Abrasive"}
GroupSquareWolf
Thank you for pointing out the Srcipting index, it is really helpful.
A further question: does the "list of the worksheet names" have to be strings? Can they be string variables?
Here is an example I am struggling with:
The script below creates three datatables based on :Column 2 values, then save three separate sheets in one Excel files. I would like to name each worksheet based on :Column 2 values, but when I put GroupBy variable as the worksheet names (the red script below), it does not assign :Column 2 value to each worksheet.
dt = current datatable();
Summarize (dt, GroupBy = By (:Column 2) );
For ( i=1, i<= N items (GroupBy), i++,
dt<< select where (:Column 2 == GroupBy [i]);
dt2= dt << subset (
	Selected Rows( 1 ),
	Selected columns only( 0 )
show (dt2);
show (GroupBy[i]);
Create Excel Workbook ("$DESKTOP/Untitled1.xlsx", {dt2}, GroupBy[i]);
Thank you for your help!
tempList = {};
