I am scripting a dashboard with graph builder in it. I want to add a column switcher that should use a variable as a column list, due to changing columns. For some reason this doesn't work, only first column in a list will show. Column list is created like this:
col_list3 = dt << get column names(Numeric);
for (i = nitems(col_list3), i > 0, i--,
if (!contains(col_list3[i], "%"),
remove from(col_list3, i);
But when I try to use col_list3 in the Column Switcher embedded in dasboard script, it doesn't work.
Column Switcher(
:FC 1244%,
{col_list3}
I have tried to use eval ect., but no success. What am I missing, any Ideas? For some reason I can't add any files to this post so whole script pasted below and a image of my example data table.
Names default to here (1);
dt = Data Table("example");
//get only columns with %
//dashboard
JMP App(
Set Name( "Dashboard" ),
Set Description( "Selection in one report filters the second" ),
Auto Launch( 1 ),
Snap To Grid( 1 ),
Show Grid( 1 ),
Show Properties( 0 ),
Show Sources( 1 ),
Group By Category( 0 ),
Dashboard Mode( 1 ),
Parameters,
Tables(
DataTable1 = GuiTable(
Set Path( "" ),
Set Label( "example" ),
Set Location( "Current Data Table" ),
Set Invisible( 0 )
Thumbnail(
New Image(
Char To Blob(
"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",
"base64compressed"
"png"
Script(JSL Quote(// This script is executed when the application is run.
// Named objects have been created for the application modules
// (for example, "Module1") and the pre-defined object
// "thisApplication" refers to the application object itself.
// Variables and functions declared here are scoped to the
// Application namespace.
Allocate(
Module1 = Plan(
PreAllocate,
Script(JSL Quote( thisModuleInstance << Create Objects; Try(MainTabPage << Set Scriptable Object(thisApplication));
Allocate(
DataFilterContext1 = Data Filter Context Box();
MainTabPage = Tab Page Box();
Splitter1 = H Splitter Box();
DataFilterSource1 = Data Filter Source Box();
TabPage1 = Tab Page Box();
Scroll1 = Scroll Box();
Report1 = Platform(
DataTable1,
Distribution(
Automatic Recalc( 1 ),
Nominal Distribution( Column( :Product ) )
TabPage2 = Tab Page Box();
Scroll2 = Scroll Box();
Report2 = Platform(
DataTable1,
Graph Builder(
Size( 534, 448 ),
Fit to Window( "Maintain Aspect Ratio" ),
Variables( X( :DAY ), Y( :FC 1244% ) ),
Elements( Points( X, Y, Legend( 3 ) ) ),
Column Switcher(
:FC 1244%,
{col_list3} //not working
Organize(
Reparent( Scroll2( Report2 ) );
Reparent( TabPage2( Scroll2 ) );
Reparent( Splitter1( TabPage2 ) );
Reparent( Scroll1( Report1 ) );
Reparent( TabPage1( Scroll1 ) );
Reparent( DataFilterSource1( TabPage1 ) );
Reparent( Splitter1( DataFilterSource1 ) );
Reparent( MainTabPage( Splitter1 ) );
Reparent( DataFilterContext1( MainTabPage ) );
Relocate( DataFilterContext1( 0, 0 ) );
Initialize(
DataFilterContext1 << Background Color( 2147483647 ),
DataFilterContext1 << Border(
{Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )}
DataFilterContext1 << Enabled( 1 ),
DataFilterContext1 << Horizontal Alignment( "Default" ),
DataFilterContext1 << Margin(
DataFilterContext1 << Padding(
DataFilterContext1 << Text Color( 2147483647 ),
DataFilterContext1 << Vertical Alignment( "Default" ),
DataFilterContext1 << Visibility( "Visible" ),
MainTabPage << Background Color( 2147483647 ),
MainTabPage << Border(
MainTabPage << Enabled( 1 ),
MainTabPage << Horizontal Alignment( "Default" ),
MainTabPage << Margin(
MainTabPage << Padding(
MainTabPage << Text Color( 2147483647 ),
MainTabPage << Vertical Alignment( "Default" ),
MainTabPage << Visibility( "Visible" ),
MainTabPage << Title( "Dashboard" ),
MainTabPage << Tip( "" ),
MainTabPage << Icon( "" ),
MainTabPage << Closeable( 0 ),
MainTabPage << Moveable( 0 ),
Splitter1 << Background Color( 2147483647 ),
Splitter1 << Border(
Splitter1 << Enabled( 1 ),
Splitter1 << Horizontal Alignment( "Default" ),
Splitter1 << Margin(
Splitter1 << Padding(
Splitter1 << Text Color( 2147483647 ),
Splitter1 << Vertical Alignment( "Default" ),
Splitter1 << Visibility( "Visible" ),
Splitter1 << Dockable( 1 ),
Splitter1 << Set Width( 1036 ),
Splitter1 << Set Height( 500 ),
Splitter1 << Set Sizes( {0.210067763794773, 0.789932236205227} ),
Splitter1 << set horizontal( 1 ),
Splitter1 << Set Min Size( 456, 193 ),
Splitter1 << Set Max Size( 60003, 30000 ),
Splitter1 << Set Auto Stretching( 1, 1 ),
DataFilterSource1 << Background Color( 2147483647 ),
DataFilterSource1 << Border(
DataFilterSource1 << Enabled( 1 ),
DataFilterSource1 << Horizontal Alignment( "Default" ),
DataFilterSource1 << Margin(
DataFilterSource1 << Padding(
DataFilterSource1 << Text Color( 2147483647 ),
DataFilterSource1 << Vertical Alignment( "Default" ),
DataFilterSource1 << Visibility( "Visible" ),
TabPage1 << Background Color( 2147483647 ),
TabPage1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
TabPage1 << Enabled( 1 ),
TabPage1 << Horizontal Alignment( "Default" ),
TabPage1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
TabPage1 << Padding(
TabPage1 << Text Color( 2147483647 ),
TabPage1 << Vertical Alignment( "Default" ),
TabPage1 << Visibility( "Visible" ),
TabPage1 << Title( "Distributions" ),
TabPage1 << Tip( "" ),
TabPage1 << Icon( "Distrib" ),
TabPage1 << Closeable( 1 ),
TabPage1 << Moveable( 1 ),
Scroll1 << Background Color( 2147483647 ),
Scroll1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Scroll1 << Enabled( 1 ),
Scroll1 << Horizontal Alignment( "Default" ),
Scroll1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Scroll1 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Scroll1 << Text Color( 2147483647 ),
Scroll1 << User Resizable( {1, 1} ),
Scroll1 << Vertical Alignment( "Default" ),
Scroll1 << Visibility( "Visible" ),
Scroll1 << Width( 218 ),
Scroll1 << Height( 474 ),
Scroll1 << Set Auto Scrollable( 1 ),
Scroll1 << Set Scrollers( 1, 1 ),
Scroll1 << Set Background Color( 2147483647 ),
Scroll1 << Set Show Empty( 0 ),
Scroll1 << Set Clip Printing( 0 ),
Scroll1 << Set Min Size( 72, 36 ),
Scroll1 << Set Max Size( 30000, 30000 ),
Scroll1 << Set Auto Stretching( 1, 1 ),
Report1 << Background Color( 2147483647 ),
Report1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Report1 << Enabled( 1 ),
Report1 << Horizontal Alignment( "Default" ),
Report1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Report1 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Report1 << Text Color( 2147483647 ),
Report1 << Vertical Alignment( "Default" ),
Report1 << Visibility( "Visible" ),
Report1 << set horizontal( 0 ),
TabPage2 << Background Color( 2147483647 ),
TabPage2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
TabPage2 << Enabled( 1 ),
TabPage2 << Horizontal Alignment( "Default" ),
TabPage2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
TabPage2 << Padding(
TabPage2 << Text Color( 2147483647 ),
TabPage2 << Vertical Alignment( "Default" ),
TabPage2 << Visibility( "Visible" ),
TabPage2 << Title( "TabPage2" ),
TabPage2 << Tip( "" ),
TabPage2 << Icon( "Trellis" ),
TabPage2 << Closeable( 1 ),
TabPage2 << Moveable( 1 ),
Scroll2 << Background Color( 2147483647 ),
Scroll2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Scroll2 << Enabled( 1 ),
Scroll2 << Horizontal Alignment( "Default" ),
Scroll2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Scroll2 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Scroll2 << Text Color( 2147483647 ),
Scroll2 << User Resizable( {1, 1} ),
Scroll2 << Vertical Alignment( "Default" ),
Scroll2 << Visibility( "Visible" ),
Scroll2 << Width( 815 ),
Scroll2 << Height( 474 ),
Scroll2 << Set Auto Scrollable( 1 ),
Scroll2 << Set Scrollers( 0, 0 ),
Scroll2 << Set Background Color( 2147483647 ),
Scroll2 << Set Show Empty( 0 ),
Scroll2 << Set Clip Printing( 0 ),
Scroll2 << Set Min Size( 381, 167 ),
Scroll2 << Set Max Size( 30281, 30026 ),
Scroll2 << Set Auto Stretching( 1, 1 ),
Report2 << Background Color( 2147483647 ),
Report2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Report2 << Enabled( 1 ),
Report2 << Horizontal Alignment( "Default" ),
Report2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Report2 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
Report2 << Text Color( 2147483647 ),
Report2 << Vertical Alignment( "Default" ),
Report2 << Visibility( "Visible" ),
Report2 << set horizontal( 0 )
Initialize(
Module1 << Auto Launch( 1 );
Module1 << Set Module Type( "Report" );
Module1 << Set Window Title( "^TABLENAME - ^APPNAME" );
Module1 << Set Min Size( 0, 0 );
Module1 << Set Max Size( 30000, 30000 );
Module1 << Set Auto Stretching( ., . );
) << Run
