mes
mes
Scripting column switcher using variable
I am scripting a dashboard with graph builder in it. I want to add a column switcher that should use a variable as a column list, due to changing columns. For some reason this doesn't work, only first column in a list will show. Column list is created like this:
col_list3 = dt << get column names(Numeric);
for (i = nitems(col_list3), i > 0, i--,
if (!contains(col_list3[i], "%"),
remove from(col_list3, i);
But when I try to use col_list3 in the Column Switcher embedded in dasboard script, it doesn't work.
Column Switcher(
:FC 1244%,
{col_list3}
I have tried to use eval ect., but no success. What am I missing, any Ideas? For some reason I can't add any files to this post so whole script pasted below and a image of my example data table.
Names default to here (1);
dt = Data Table("example");
//get only columns with %
//dashboard
JMP App(
	Set Name( "Dashboard" ),
	Set Description( "Selection in one report filters the second" ),
	Auto Launch( 1 ),
	Snap To Grid( 1 ),
	Show Grid( 1 ),
	Show Properties( 0 ),
	Show Sources( 1 ),
	Group By Category( 0 ),
	Dashboard Mode( 1 ),
	Parameters,
	Tables(
		DataTable1 = GuiTable(
			Set Path( "" ),
			Set Label( "example" ),
			Set Location( "Current Data Table" ),
			Set Invisible( 0 )
	Thumbnail(
		New Image(
			Char To Blob(
				"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",
				"base64compressed"
			"png"
	Script(JSL Quote(// This script is executed when the application is run.
// Named objects have been created for the application modules
// (for example, "Module1") and the pre-defined object
// "thisApplication" refers to the application object itself.
// Variables and functions declared here are scoped to the
// Application namespace.
	Allocate(
		Module1 = Plan(
			PreAllocate,
			Script(JSL Quote(				thisModuleInstance << Create Objects;				Try(MainTabPage << Set Scriptable Object(thisApplication));
			Allocate(
				DataFilterContext1 = Data Filter Context Box();
				MainTabPage = Tab Page Box();
				Splitter1 = H Splitter Box();
				DataFilterSource1 = Data Filter Source Box();
				TabPage1 = Tab Page Box();
				Scroll1 = Scroll Box();
				Report1 = Platform(
					DataTable1,
					Distribution(
						Automatic Recalc( 1 ),
						Nominal Distribution( Column( :Product ) )
				TabPage2 = Tab Page Box();
				Scroll2 = Scroll Box();
				Report2 = Platform(
					DataTable1,
					Graph Builder(
						Size( 534, 448 ),
						Fit to Window( "Maintain Aspect Ratio" ),
						Variables( X( :DAY ), Y( :FC 1244% ) ),
						Elements( Points( X, Y, Legend( 3 ) ) ),
						Column Switcher(
							:FC 1244%,
							{col_list3} //not working
			Organize(
				Reparent( Scroll2( Report2 ) );
				Reparent( TabPage2( Scroll2 ) );
				Reparent( Splitter1( TabPage2 ) );
				Reparent( Scroll1( Report1 ) );
				Reparent( TabPage1( Scroll1 ) );
				Reparent( DataFilterSource1( TabPage1 ) );
				Reparent( Splitter1( DataFilterSource1 ) );
				Reparent( MainTabPage( Splitter1 ) );
				Reparent( DataFilterContext1( MainTabPage ) );
				Relocate( DataFilterContext1( 0, 0 ) );
			Initialize(
				DataFilterContext1 << Background Color( 2147483647 ),
				DataFilterContext1 << Border(
					{Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )}
				DataFilterContext1 << Enabled( 1 ),
				DataFilterContext1 << Horizontal Alignment( "Default" ),
				DataFilterContext1 << Margin(
				DataFilterContext1 << Padding(
				DataFilterContext1 << Text Color( 2147483647 ),
				DataFilterContext1 << Vertical Alignment( "Default" ),
				DataFilterContext1 << Visibility( "Visible" ),
				MainTabPage << Background Color( 2147483647 ),
				MainTabPage << Border(
				MainTabPage << Enabled( 1 ),
				MainTabPage << Horizontal Alignment( "Default" ),
				MainTabPage << Margin(
				MainTabPage << Padding(
				MainTabPage << Text Color( 2147483647 ),
				MainTabPage << Vertical Alignment( "Default" ),
				MainTabPage << Visibility( "Visible" ),
				MainTabPage << Title( "Dashboard" ),
				MainTabPage << Tip( "" ),
				MainTabPage << Icon( "" ),
				MainTabPage << Closeable( 0 ),
				MainTabPage << Moveable( 0 ),
				Splitter1 << Background Color( 2147483647 ),
				Splitter1 << Border(
				Splitter1 << Enabled( 1 ),
				Splitter1 << Horizontal Alignment( "Default" ),
				Splitter1 << Margin(
				Splitter1 << Padding(
				Splitter1 << Text Color( 2147483647 ),
				Splitter1 << Vertical Alignment( "Default" ),
				Splitter1 << Visibility( "Visible" ),
				Splitter1 << Dockable( 1 ),
				Splitter1 << Set Width( 1036 ),
				Splitter1 << Set Height( 500 ),
				Splitter1 << Set Sizes( {0.210067763794773, 0.789932236205227} ),
				Splitter1 << set horizontal( 1 ),
				Splitter1 << Set Min Size( 456, 193 ),
				Splitter1 << Set Max Size( 60003, 30000 ),
				Splitter1 << Set Auto Stretching( 1, 1 ),
				DataFilterSource1 << Background Color( 2147483647 ),
				DataFilterSource1 << Border(
				DataFilterSource1 << Enabled( 1 ),
				DataFilterSource1 << Horizontal Alignment( "Default" ),
				DataFilterSource1 << Margin(
				DataFilterSource1 << Padding(
				DataFilterSource1 << Text Color( 2147483647 ),
				DataFilterSource1 << Vertical Alignment( "Default" ),
				DataFilterSource1 << Visibility( "Visible" ),
				TabPage1 << Background Color( 2147483647 ),
				TabPage1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage1 << Enabled( 1 ),
				TabPage1 << Horizontal Alignment( "Default" ),
				TabPage1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage1 << Padding(
				TabPage1 << Text Color( 2147483647 ),
				TabPage1 << Vertical Alignment( "Default" ),
				TabPage1 << Visibility( "Visible" ),
				TabPage1 << Title( "Distributions" ),
				TabPage1 << Tip( "" ),
				TabPage1 << Icon( "Distrib" ),
				TabPage1 << Closeable( 1 ),
				TabPage1 << Moveable( 1 ),
				Scroll1 << Background Color( 2147483647 ),
				Scroll1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll1 << Enabled( 1 ),
				Scroll1 << Horizontal Alignment( "Default" ),
				Scroll1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll1 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll1 << Text Color( 2147483647 ),
				Scroll1 << User Resizable( {1, 1} ),
				Scroll1 << Vertical Alignment( "Default" ),
				Scroll1 << Visibility( "Visible" ),
				Scroll1 << Width( 218 ),
				Scroll1 << Height( 474 ),
				Scroll1 << Set Auto Scrollable( 1 ),
				Scroll1 << Set Scrollers( 1, 1 ),
				Scroll1 << Set Background Color( 2147483647 ),
				Scroll1 << Set Show Empty( 0 ),
				Scroll1 << Set Clip Printing( 0 ),
				Scroll1 << Set Min Size( 72, 36 ),
				Scroll1 << Set Max Size( 30000, 30000 ),
				Scroll1 << Set Auto Stretching( 1, 1 ),
				Report1 << Background Color( 2147483647 ),
				Report1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report1 << Enabled( 1 ),
				Report1 << Horizontal Alignment( "Default" ),
				Report1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report1 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report1 << Text Color( 2147483647 ),
				Report1 << Vertical Alignment( "Default" ),
				Report1 << Visibility( "Visible" ),
				Report1 << set horizontal( 0 ),
				TabPage2 << Background Color( 2147483647 ),
				TabPage2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage2 << Enabled( 1 ),
				TabPage2 << Horizontal Alignment( "Default" ),
				TabPage2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage2 << Padding(
				TabPage2 << Text Color( 2147483647 ),
				TabPage2 << Vertical Alignment( "Default" ),
				TabPage2 << Visibility( "Visible" ),
				TabPage2 << Title( "TabPage2" ),
				TabPage2 << Tip( "" ),
				TabPage2 << Icon( "Trellis" ),
				TabPage2 << Closeable( 1 ),
				TabPage2 << Moveable( 1 ),
				Scroll2 << Background Color( 2147483647 ),
				Scroll2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll2 << Enabled( 1 ),
				Scroll2 << Horizontal Alignment( "Default" ),
				Scroll2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll2 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll2 << Text Color( 2147483647 ),
				Scroll2 << User Resizable( {1, 1} ),
				Scroll2 << Vertical Alignment( "Default" ),
				Scroll2 << Visibility( "Visible" ),
				Scroll2 << Width( 815 ),
				Scroll2 << Height( 474 ),
				Scroll2 << Set Auto Scrollable( 1 ),
				Scroll2 << Set Scrollers( 0, 0 ),
				Scroll2 << Set Background Color( 2147483647 ),
				Scroll2 << Set Show Empty( 0 ),
				Scroll2 << Set Clip Printing( 0 ),
				Scroll2 << Set Min Size( 381, 167 ),
				Scroll2 << Set Max Size( 30281, 30026 ),
				Scroll2 << Set Auto Stretching( 1, 1 ),
				Report2 << Background Color( 2147483647 ),
				Report2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report2 << Enabled( 1 ),
				Report2 << Horizontal Alignment( "Default" ),
				Report2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report2 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report2 << Text Color( 2147483647 ),
				Report2 << Vertical Alignment( "Default" ),
				Report2 << Visibility( "Visible" ),
				Report2 << set horizontal( 0 )
	Initialize(
		Module1 << Auto Launch( 1 );
		Module1 << Set Module Type( "Report" );
		Module1 << Set Window Title( "^TABLENAME - ^APPNAME" );
		Module1 << Set Min Size( 0, 0 );
		Module1 << Set Max Size( 30000, 30000 );
		Module1 << Set Auto Stretching( ., . );
) << Run
Re: Scripting column switcher using variable
The issue you are having, is that when you specify
Column Switcher(
:FC 1244%,
{col_list3}
you are placing col_list3 inside a set of {}.  But since col_list3 has been specified as a list, it already has the {} in the list.  So what JMP is seeing is a list within a list
Here is a simple script to illustrate how to code what you want
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
col_list3 = dt << get column names( Numeric );
For( i = N Items( col_list3 ), i > 0, i--,
	If( !Contains( col_list3[i], "PN" ),
		Remove From( col_list3, i )
Graph Builder(
	Size( 534, 572 ),
	Variables( X( :PNP1 ), Y( :NPN1 ) ),
	Elements( Points( X, Y, Legend( 3 ) ), Smoother( X, Y, Legend( 4 ) ) ),
	Column Switcher( :NPN1, col_list3 )
Column Switcher(
:FC 1244%,
{col_list3}
Graph Builder(
	Size( 534, 572 ),
mes
mes
That was the problem, thank you :)!
HubP_SDe
Never mind, the variable was simply undefined in my local context!
Did not manage to remove this post...
Dear all,
Facing the same issue, this solution does not solve my issue, supposedly because my columns have more complex names and the list variable contains quotes:
colList = {"Time At Entrance Queue", "Time At Check-In", ...,
"Total Time From Last Chute To Exit", "EBS Total Duration", "Flight ID", "BAG ID", "PAX ID", "CheckInQueue", "CheckIn", "CheckInCollector", "TransferCollector", "Presortation", "Dep-Reader-TimeStamp", "ICS-Loader", "ICS-Unloader", "Last Chute", "MakeUp", "MakeUp Group", "Stopped", "Before WarmUp", "PBC Type", "Recirculation", "HBS_1_Index", "HBS_2_Index", "HBS_3_Index", "HBS_4_Index", "HBS_5_Index", "IntLnk", "MES_Index", "EBS_Index", "Transfer Infeed Desk", "Transfer Infeed Queue", "ORIGINATING", "HBS3-b", "MES-b", "EBS-b"};
In the following script, error marked by /*###*/
Column Switcher( :Total Time From CheckIn Collector To Exit, colList/*###*/ ),
Any workaround of your knowledge?
Thanks
Stéphane DELACROIX
Senior Simulation & Planning Engineer
I am assuming that your colList entry of ..., is a reference to more values follow, and not an actual entry.
You should try running with placing an Eval() function on the colList
Eval( colList )
HubP_SDe
Hi Jim,
Indeed, the list was much longer, just made it shorter.
The original solution of this post finally worked fine, after I understood that my variable was not defined in the local context where I tried to use it ;)
I just did not find how to remove my post after I found out :(
Cheers!
Stéphane DELACROIX
