QCSci_CK
Script to select to generate an options menu to select columns and rows based on multiple parameters.
I have been trying to teach myself JSL and after going back through the Introduction to the JMP Scripting Language again, I rediscovered the "Make Specific Report" script which allows for the selection of a specific date range (row selection) and Die temperatures (column selection) from the "Process data" data table. I have been trying to make a similar script and apply it to some stability data and have been running into a wall.
I am trying to write a script that will open an options window similar to the "Make Specific Report" that will allow a users to select the lot numbers,  stability conditions (temperatures) and the specific assays that are needed to perform additional analysis.
In the column "lot number" there are a list of lot numbers which are repeated for each time point.
In the column " temperature" there are 3 temperatures that are repeated for each lot & time point.
Then there are a number of columns for each assay
So essentially tying to build three options
Select lot number(s)
Select Temperatures(s)
Select Assay(s)
then it returns a new data table with the selected data
Any help would be appreciated.
Re: Script to select to generate an options menu to select columns and rows based on multiple parameters.
Could you do this just by utilizing (Local) Data filter?
