shampton82
Level VIII
Script to make a toolbar button to turn on and off graph builder fit to window
Hey everyone,
I was wondering if someone could help me out with a script that I could assign to my toolbar so that I could "one click" turn graph builders "Fit to Window" options on and off
So if it I clicked it and the current selection was "Auto/On/MAR" then it would set Fit to Window to "Off" and if the current section was "Off" then it would set Fit to Window to "On".
Thanks for any input on how to do this!
Steve
Re: Script to make a toolbar button to turn on and off graph builder fit to window
I'm not sure if there is any direct message to get the current Fit To Window setting, but something like this might work
gb_ref = (Current Report() << XPath("//OutlineBox[@helpKey = 'Graph Builder']"))[1] << Get Scriptable Object;
cur_stretch = All(gb_ref << Get Auto Stretching);
If(cur_stretch,
	gb_ref << Fit to Window("Off")
	gb_ref << Fit to Window("On")
If(cur_stretch,
shampton82
Level VIII
Looks like that worked!  Thanks a ton.
One last little ask, what would need to be added to the current state to the subtitle?  So something like this?
Not sure if it has any specific message either, but you can try to find the text edit box (this isn't the most robust option but should work in simple cases)
fit_state = If(cur_stretch, "Off", "On");
gb_ref << Fit to Window(fit_state);
Report(gb_ref)[GraphBuilderTitleBox(2), TextEditBox(1)] << Set Text(Eval Insert("FTW = ^fit_state^"));
If you want to make sure that the subtitle is visible you can add
gb_ref << Show Subtitle(1);
to end
shampton82
Level VIII
You rock Jarmo, thanks for all the great help (as usual)!
Steve
