hogi
Level XIII
overlapping points with Overlay
I want to use Overlay to get different markers and legend entries for a subset of my data points.
Unfortunately, as soon as I activate Overlay, the points with the special markers overlap with the other points (top graph):
What is the best way to get:
- the markers
- the legend entries
- non-overlapping, nicely positioned data points
View more...
Names Default to Here(1);
Graph Builder(
	Transform Column(
		"Custom Binning...[weight]",
		Numeric,
		Nominal,
		Value Labels( {"." = "Missing", 79 = "< 80", 80 = "≥ 80"} ),
		Use Value Labels( 1 ),
		Formula( If( :weight < 80, 79, :weight >= 80, 80, . ) )
	Transform Column(
		"age'",
		Ordinal,
		Set Property( "Configure Levels", 1 ),
		Set Property( "Value Order", {Custom Order( {12, 15} )} ),
		Value Labels( {12 = "12-14", 15 = "15-17"} ),
		Formula(
			Map Value( :age, {13, 12, 14, 12, 16, 15, 17, 15}, Unmatched( :age ) )
	Size( 469, 709 ),
	Show Control Panel( 0 ),
	Summary Statistic( "Median" ),
	Graph Spacing( 4 ),
	Variables(
		X( :sex ),
		Y( :age' ),
		Y( :age' ),
		Overlay( :"Custom Binning...[weight]"n ),
		Color( :height )
	Elements(
		Position( 1, 1 ),
		Points( X, Y, Legend( 16 ), Jitter( "Centered Grid" ) )
	Elements(
		Position( 1, 2 ),
		Points( X, Y, Overlay( 0 ), Legend( 17 ), Jitter( "Centered Grid" ) )
		Dispatch( {}, "age'", ScaleBox,
			{Min( -0.5 ), Max( 1.65217391304348 ), Inc( 1 ), Minor Ticks( 0 )}
		Dispatch( {}, "400", ScaleBox,
			{Legend Model(
				16,
				Properties( 1, {Marker Size( 20 )}, Item ID( "< 80", 1 ) ),
				Properties(
					2,
					{Marker( "FilledCircle" ), Marker Size( 20 )},
					Item ID( "≥ 80", 1 )
				Properties( -1, {Marker( "FilledCircle" )}, Item ID( "M", 1 ) ),
				Properties( -1, {Marker Size( 20 )}, Item ID( "age'", 1 ) )
			), Legend Model(
				17,
				Properties( 1, {Marker Size( 20 )}, Item ID( "age'", 1 ) )
		Dispatch( {}, "Graph Builder", FrameBox,
			{Marker Drawing Mode( "Outlined" )}
		Dispatch( {}, "Graph Builder", FrameBox( 2 ),
arawlings
Re: overlapping points with Overlay
Have you tried working on the "jitter"? There are plenty of options on how to lay out the points.
Default is to "auto" but you can choose a different option. It looks like you are using "Centered Grid" - try "Auto" or "Random Uniform".
You can also move the Jitter Limit bar; the farther to the right, the more space there is in between your points.
hogi
Level XIII
the goal: something like this one, but with green triangles at position 1-N
