saitcopuroglu
Script for dynamic date/time axising
I need to reproduce a report every day and the x axis date/time variable should show only the last seven days, and same goes for tabulate and etc... Is there a way to tell JMP by a script?
Thank you all in advance
ms
Super User (Alumni) ms
Re: Script for dynamic date/time axising
The  Min( 3505939200 ), Max( 3510000000 ) forces the axis to hose limits. Try to delete the entire Send to report(...) part.
Or change it into something like:
Min(today()-in days(7)), Max(today())
9 REPLIES 9
ms
There are multiple ways, as usual, to do it by script. One approach is to hide and exclude the "too old" data table rows.
dt << select where(:Name("Date/Time") < Today() - In Days(7));
dt << hide and exclude << clear select;
saitcopuroglu
Thank you.
Even the Data is not displayed, the time axis still displays the hidden/excluded rows.
I actually need both not to be displayed. Does the same script go for the x axis display?
dt << select where(:Name("SalesDate") < Today() - In Days(7));
ms
Graph Builder usually adapts the axes automatically to show the range of included data only. Are you sure you haven't hard coded the x-axis limits? Check the graph builder script.
saitcopuroglu
"Hard-Coding x-axis limits"? I am afraid I am unaware of that term.
Graph Builder(
  Title Fill Color( "Light Blue" ),
  Title Frame Color( "Medium Dark Gray" ),
  Level Fill Color( {174, 203, 228} ),
  Level Frame Color( "Medium Dark Gray" ),
  Level Underline( 1 ),
  Variables( X( :SalesDate ), Y( :NetRevenue ) ),
  Elements(
  Points( X, Y, Legend( 1 ), Jitter( 1 ) ),
  Smoother( X, Y, Legend( 2 ) )
  Dispatch(
  "SalesDate",
  ScaleBox,
  {Min( 3505939200 ), Max( 3510000000 ), Interval( "Day" ), Inc( 1 ),
  Minor Ticks( 0 ), Show Major Grid( 1 ), Inside Ticks( 1 ),
  Rotated Labels( "Vertical" )}
ms
saitcopuroglu
Deleting the entire Send To( did not but rewriting the min-max helped.
Thank you a lot!
saitcopuroglu
Hi again,
Would you please keep helping by;
Dynamic date/time scripting for tabulate?
I am okay with graph builder but need to do it also within tabulate local data filter:
I tried to do something like you did with graph builder
  Local Data Filter(
  Location( {56, 0} ),
  Mode( Select( 0 ), Show( 1 ), Include( 1 ) ),
  Add Filter(
  columns( :SalesDate ),
  Where( :SalesDate >= 20Feb2015 & :SalesDate < 14Mar2015 ),
  Display( :SalesDate )
to something like this but it does not work.
  Local Data Filter(
  Location( {34, 0} ),
  Add Filter(
  Where(:Name("SalesDate") < Today() - In Days(7)),
Thank you for your help.
ms
It should work fine if you add the missing ")".
tb = Tabulate(...);
tb << Local Data Filter(
    Add Filter(
        columns(:SalesDate),
        Display(:SalesDate)
WebDesignesCrow
Thanks MS. This is what I'm looking for for my work as well
