Steve_Kim
[Script] Get rid of Moving Range chart in control chart builder
Hello~ all~
Is there a way to get rid of Moving Range chart
in the 'Control chart builder' platform
by using JMP script? : )
Here is the script for the 'control chart builder' sample.
dt = Open( "$SAMPLE_DATA/Quality Control/Coating.jmp" );
dt << Control Chart Builder(
Show Control Panel( 0 ),
Variables( Subgroup( :Pin ), Y( :Weight ) ),
Chart( Position( 1 ), Limits( Spec Limits( 1 ) ), Warnings( Test 1( 1 ) ) ),
Chart( Position( 2 ) ),
SendToReport( Dispatch( {}, "graph title", TextEditBox, {Set Text( "Individual chart of Weight" )} ) )
13 REPLIES 13
Re: [Script] Get rid of Moving Range chart in control chart builder
Here is a script using the Big Class data table, and your script, running in JMP 12.2 and it seems to work great
	Show Two Shewhart Charts( 0 ),
	Size( 650, 500 ),
	Show Capability( 0 ),
	Variables( Subgroup( :age ), Y( :height ) ),
	Customize Tests( Test 2( 8, "2" ), Test 3( 7, "3" ) ),
	Chart(
		Position( 1 ),
		Points( Statistic( "Individual" ) ),
		Limits( Sigma( "Moving Range" ) ),
		Warnings( Test 1( 1 ), Test 2( 1 ), Test 3( 1 ) )
Paul_J
Thanks, but it doen't work for me.  Must be something specific about 12.1.0 (not Pro).  Good to know at least this will be fixed in a later version, though I hope it will be fixed in the non-pro version.
You should be able to go to the JMP update site and for free download 12.2
Paul_J
The script I have creates the chart then saves it to a journal.  Is there any way to pause the script so the user can manually remove the Range chart, then continue the script which saves the chart to a journal (and does other stuff)?
Thanks.
