BookmarkSubscribeRSS Feed
Paul_J
Community Trekker
Re: [Script] Get rid of Moving Range chart in control chart builder
Thanks, but it doen't work for me.  Must be something specific about 12.1.0 (not Pro).  Good to know at least this will be fixed in a later version, though I hope it will be fixed in the non-pro version.
You should be able to go to the JMP update site and for free download 12.2
Paul_J
Community Trekker
The script I have creates the chart then saves it to a journal.  Is there any way to pause the script so the user can manually remove the Range chart, then continue the script which saves the chart to a journal (and does other stuff)?
Thanks.
