Steve_Kim
[Script] Get rid of Moving Range chart in control chart builder
Hello~ all~
Is there a way to get rid of Moving Range chart
in the 'Control chart builder' platform
by using JMP script? : )
Here is the script for the 'control chart builder' sample.
dt = Open( "$SAMPLE_DATA/Quality Control/Coating.jmp" );
dt << Control Chart Builder(
Variables( Subgroup( :Pin ), Y( :Weight ) ),
Chart( Position( 1 ), Limits( Spec Limits( 1 ) ), Warnings( Test 1( 1 ) ) ),
Chart( Position( 2 ) ),
SendToReport( Dispatch( {}, "graph title", TextEditBox, {Set Text( "Individual chart of Weight" )} ) )
12 REPLIES 12
louv
Staff (Retired)
Re: [Script] Get rid of Moving Range chart in control chart builder
James,
It is very subtle, if place your cursor on the Y-axis of the Moving range just until the hand is facing up (this is somewhat tricky),  then drag the hand (axis) to the left and the Moving Range chart will disappear.
Steve_Kim
Thank you so much~ LouV,
But my question is ... remove the 'Moving Range chart' by using JMP script...
[1] I'm currently use JMP 11.
    I can click the mouse right button and 'Remove' button to remove it, but there are over 100 control charts.  So I have to use JMP script.
[2] I thought that if I delete the 'Chart (Position (2))' in the script
    , then  I could remove the 2nd control chart which is 'Moving Range chart' but it couldn't. (It feels bug ... Maybe I don't know how to change it )
dt << Control Chart Builder( Show Control Panel( 0 ),
[3] I know there is a 'IR' menu for I chart
     , but I have to use 'control chart builder' menu  to customize the rule 2. (form 9 to 8 points)
-----------  or  --------------
Maybe I have to use 'I' chart menu...
adding formula with label funtion for Rule 2 (Marks on the 8points)   (Default : marks from 9points)
KarenC
James,
When I made up an example, removed the MR chart and saved the script I get at "Show Two Shewhart Charts (0)" line of code...if it is set to 1 I get both charts, 0 to get one chart.  The line of code only appeared in the saved script AFTER I manually removed the chart, the joys of JSL?
Karen
  Show Two Shewhart Charts( 0 ),
  Show Capability( 0 ),
  Variables( Y( :column name ) ),
  Chart( Points( Statistic( "Individual" ) ), Limits( Sigma( "Moving Range" ) ) )
Steve_Kim
Hello Karen~~
Thank you for your advice~!
Yes~~  That's it, but it's not working. I dont know why..
I also tried it with other computers, but it doesn't work.  (JMP Version 11.2.1)
(File > Preferences > Platforms > Control Chart Builder :  Inactivate "Show Two Shewhart Chart")
        Chart(  Points( Statistic( "Individual" ) ),  Limits( Sigma( "User Defined" ), Spec Limits( 1 ) ),  Warnings( Test 1( 1 ), Test 2( 1 ), Test 3( 1 ) ) )
KarenC
Don't ask me why, I am just a JSL hack.  Swap the Show Control Panel and Show Two Stewart Chart commands so that the two chart command is first.  That worked for me.
Karen
wendy_o
Karen@boulderstats is correct. If you put the Show Two Shewhart Charts (0) statement first, you'll get the single individuals chart.
Note: If you place that statement second (or beyond) in your chart builder script, you'll get the default of two Shewhart charts (regardless of your preference setting and regardless of whether you put 1 or 0 in the Shewhart line of the script.
jmpbeginner
Thanks Karen!  placing the Show Two Shewhart Charts (0) statement first worked  for me --I also had to remove the reference to Chart Position 2 to get it to work:
delete or comment out this line:
Paul_J
Thanks for the information on how to remove the mR chart with JSL.  Unfortunately it's not working for me, and anyone has a solution that would be greatly appreciated.  I am using JMP 12.1.0, have placed the TwoCharts(0) first, and taken out the Chart(Position(2)), but am still getting both charts.  Below is the code I am using.  Thanks Again!
Show Two Shewhart Charts(0),
Size( 650, 500 ),
Variables( Subgroup( :Batch ), Y( :Peak ) ),
Customize Tests( Test 2( 8, "2" ), Test 3( 7, "3" ) ),
Limits( Sigma( "Moving Range" ) ),
Here is a script using the Big Class data table, and your script, running in JMP 12.2 and it seems to work great
	Size( 650, 500 ),
	Variables( Subgroup( :age ), Y( :height ) ),
	Chart(
		Position( 1 ),
