Script Error
While running the JMP script, I am getting the below error, could anyone help me to fix it.
Thanks in Advance!
Re: Script Error
A bit difficult to guess without seeing the code at all, but how are you trying to use batch_num? Do you have it as variable, do you have similarly named column? Do you have multiple tables open (private tables)?
