Mickyboy
Scatter plot x and y axis values
Hi All,
i would like to replicate the following scatter plots in JMP, the problem i am having is when i go to axis setting and request a log scale with a base 2 the scale starts from 1, so the scales is 1,2,4,8,16, 32, 64 etc i would like it to start at 5, 10, 20,40, 80,160,320 etc does anyone have any advice??
Any help would be appreciated.
Thanks
gzmorgan0
Re: Scatter plot x and y axis values
@Mickyboy ,
I am not sure why/where the 30 value in the saved script in JMP15 comes from.  Note you can drag using the grabber to get 5 th be the minimum on the axes.  I didn't look at your plot very closely. The line is the line Y=X and that can be added with right click Customize the FrameBox. The scipt is included below.
If using the same scales you might want to right click in the framebox, select Graph and size and scale isometric.  Up to you.
Graph Builder(
	Size( 534, 484 ),
	Show Legend( 0 ),
	Variables(
		X(
			Transform Column(
				"Transform[Ref Lab]",
				Formula( Log( :Ref Lab / 5, 2 ) )
		Y(
			Transform Column(
				"Transform[Non-Ref]",
				Formula( Log( :Name( "Non-Ref" ) / 5, 2 ) )
	Elements( Points( X, Y, Legend( 3 ) ) ),
		Dispatch(
			ScaleBox,
			{Format( "Custom", Formula( 2 ^ value * 5 ), 9 )}
		Dispatch(
			ScaleBox,
			{Format( "Custom", Formula( 2 ^ value * 5 ), 9 ), Min( 0 ), Max( 9 ),
			Inc( 1 ), Minor Ticks( 0 )}
		Dispatch( {}, "X title", TextEditBox, {Set Text( "Ref Lab" )} ),
		Dispatch( {}, "Y title", TextEditBox, {Set Text( "Non- Ref Lab" )} ),
		Dispatch(
			"Graph Builder",
			FrameBox,
			{Marker Size( 5 ), Add Graphics Script(
				2,
				Description( "Script" ),
				Pen Color( "black" );
				Pen Size( 2 );
				Line Style( "Dotted" );
				Y Function( x, x );
			), Grid Line Order( 1 ), Reference Line Order( 3 )}
18 REPLIES 18
Georg
@Mickyboy I cannot reproduce your Problem,
for me it worked, see attached JMP file (JMP15@Win10).
Perhaps you Need to again set the axis range, sometimes many steps at one don't work.
Georg
Mickyboy
Hi Georg,
Thanks for the reply, on checking my post i may not have explained that as well as i could have, l have data but l would like the the axis the same as the picture l supplied, that is a log base 2 increase commencing at 5, so 5,10,20,40,80,160,320,640 etc, which l cant seem to manage, for reference please see the attachment to this post
Thanks
gzmorgan0
@Mickyboy ,
To show you that this is possible here is a GraphBuilder plot of data I guessed from one of your plots. I added the Line of Fit and Major Grid.
The way I did this is to :
  • transform the X and Y data,
  • use a linear scale
  • but customize the format
I did this using the UI, but copied the sccript to the data table whicj is attached.
The script is shown here:
Graph Builder(
	Size( 534, 490 ),
	Show Legend( 0 ),
	Variables(
		X(
			Transform Column(
		Y(
			Transform Column(
	Elements(
		Points( X, Y, Legend( 5 ) ),
		Line Of Fit( X, Y, Legend( 7 ), Adapt to Axis Scale( 0 ) )
		Dispatch(
			ScaleBox,
			{Format( "Custom", Formula( 2 ^ value * 5 ), 9, 0 ), Min( 0 ), Max( 9 ),
			Inc( 1 ), Minor Ticks( 0 ), Label Row( Show Major Grid( 1 ) )}
		Dispatch(
			ScaleBox,
			{Format( "Custom", Formula( 2 ^ value * 5 ), 30 ),
		Dispatch( {}, "Y title", TextEditBox, {Set Text( "Non-Ref Lab" )} )
gzmorgan0
oh, since this is the first time I used this feature, I thought it might be useful to show the axis settings
Here is the Custom Format screenshot, the window that pops up when you press the Custom button
Mickyboy
Hi gzmorgan0,
Thanks for coming to my aid again, and thanks very much for your solution, its brillant, a couple of problems i have in getting the presentation l am after, and i dont know if its possible. Unfortunately l am still stuck with JMP 14 and dont have the custom area in axis setting's.trial.png
l can't get the y axis to start at 5, i have tried including the Min () and Max() into the script but to no avail
Graph Builder(
	Size( 534, 490 ),
	Show Legend( 0 ),
	Variables(
		X(
			Transform Column(
				"Transform[Lab B]",
				Formula( Log( :Lab B / 5, 2 ) )
		Y(
			Transform Column(
				"Transform[Lab A]",
				Formula( Log( :Name( "Lab A" ) / 5, 2 ) )
	Elements(
		Dispatch(
			"Transform[Lab B]",
			ScaleBox,
		Dispatch(
			"Transform[Lab A]",
			ScaleBox,
		Dispatch( {}, "X title", TextEditBox, {Set Text( "Lab B" )} ),
		Dispatch( {}, "Y title", TextEditBox, {Set Text( "Lab A" )} )
Also is it possible to have the reference line run though the graph as per the response variable in the attached data file??? l would like the line to represent where the expected titers should lie.
Again thanks very much for your help, its greatly appreciated.
gzmorgan0
@Mickyboy ,
Graph Builder(
	Size( 534, 484 ),
	Show Legend( 0 ),
	Variables(
		X(
			Transform Column(
		Y(
			Transform Column(
		Dispatch(
			ScaleBox,
		Dispatch(
			ScaleBox,
		Dispatch(
			"Graph Builder",
			FrameBox,
				2,
				Pen Size( 2 );
				Y Function( x, x );
gzmorgan0
oops forgot to add that  the above graph and script is from JMP 14
Mickyboy
Hi gzmorgan0,
l completely forgot about the grabber, the 30 in my syntax must have been a leftover from somethings l was trying, have fixed both graphs now and am very gratefull for your help, interestingly when i use the pull down menu's for graph bulider l dont get the custom button, but when i run the syntax and click on the axis for axis settings l can see the box.
Again thanks very much for your help and guidance.
Mickyboy
Hi gzmorgan0,
Something interesting happened when l ran the same syntax over another similar dataset with higher titerstrial2.png
l dont' know why but now the scaling is slight awry on both axis with 10 and 10,240 missing.
Thanks
Article Labels
