Hi gzmorgan0,
Thanks for coming to my aid again, and thanks very much for your solution, its brillant, a couple of problems i have in getting the presentation l am after, and i dont know if its possible. Unfortunately l am still stuck with JMP 14 and dont have the custom area in axis setting's.![trial.png trial.png](https://community.jmp.com/t5/image/serverpage/image-id/24921i91F479272C0CA279/image-size/large?v=v2&px=999)
l can't get the y axis to start at 5, i have tried including the Min () and Max() into the script but to no avail
Graph Builder(
Size( 534, 490 ),
Show Legend( 0 ),
Variables(
X(
Transform Column(
"Transform[Lab B]",
Formula( Log( :Lab B / 5, 2 ) )
Y(
Transform Column(
"Transform[Lab A]",
Formula( Log( :Name( "Lab A" ) / 5, 2 ) )
Elements(
Points( X, Y, Legend( 5 ) ),
Line Of Fit( X, Y, Legend( 7 ), Adapt to Axis Scale( 0 ) )
Dispatch(
"Transform[Lab B]",
ScaleBox,
{Format( "Custom", Formula( 2 ^ value * 5 ), 30 ),
Label Row( Show Major Grid( 1 ) )}
Dispatch(
"Transform[Lab A]",
ScaleBox,
Dispatch( {}, "X title", TextEditBox, {Set Text( "Lab B" )} ),
Dispatch( {}, "Y title", TextEditBox, {Set Text( "Lab A" )} )
Also is it possible to have the reference line run though the graph as per the response variable in the attached data file??? l would like the line to represent where the expected titers should lie.
Again thanks very much for your help, its greatly appreciated.
