jjswan33
Saving Journal as PNG (or PDF)
I am trying to save a very basic table as a PNG (or PDF).  I am able to create a journal with my table but haven't been able to get it to save properly.  From reading on this message board and consulting the scripting guide the below should work but it doesn't actually save anything.
Any help would be appreciated.
Names default to here(1);
dt = current data table();
path_to_results=Pick Directory("Results folder");
r = Column Dialog(
	cats = Col List("Categories", Max Col( 10 ), MinCol( 0 )),
cat = r["cats"];
st = Data Table( Eval(TableName) ) <<
Summary(
	Group(
		:Label1,
		Eval(cat)
jrn = st << Journal;
jrn << SavePDF( path_to_results||"categorychart.pdf");
jjswan33
Re: Saving Journal as PNG (or PDF)
To close this.  I was able to find a solution to do what I wanted.
I wrote a function to display my table in a new window and then saved that new window as a png file.
SplitChartCreator = Function({dt,path_to_results},{Default Local},
	r = Column Dialog(
		split = Col List("Split Columns", Max Col( 10 ), MinCol( 0 )),
	splits = r["split"];
	st = dt <<
	Summary(
		Group(
			:Lot,
			:Wafer,
			Eval(splits)
	st << Delete Columns ( "N Rows" );
	tb = Table Box();
		For (i=1,i<=NCols(st),i++,
			col = Column(st,i);
			colName = col << Get Name;
			lstValues = col << Get Values;
			type = col << Get Data Type;
			If (type=="Character",
				tb << Append(
					String Col Box(colName,lstValues)
				tb << Append(
					Number Col Box(colName,lstValues)
	content = H List Box(
		Outline Box("splitchart", << Outline Close Orientation("Vertical"),
			tb
	pw = New Window("splitchart", content);
	img = pw << getpicture();
	img << saveImage(path_to_results||"splitchart.png", "png");
	Close(st, NoSave);
	pw << Close Window();
In JMP 14, <<journal does not seem to return the journal in a useful way. Add this after you create the journal:
jrn=currentjournal();
and then save the pdf.
jjswan33
Thanks.  That does fix the problem with the SavePDF feature but alas this isn't doing what I want.  Really what I need to do is save the small table as an image rather than all the extra.   Any suggestions on how to just save a PNG with the table only?  Possibly something along the lines of creating a table in a new window and then saving an image of the new window as a PNG.
Yes. @Wendy_Murphrey  just posted an xpath way to navigate to a node in the display box tree, or you can use the display box subscripting. When you get to the right node, save it as a PNG. Something like this using display box subscripts.
from the top left red triangle in the report, Edit->Show Tree Structurefrom the top left red triangle in the report, Edit->Show Tree Structure
Use the show tree structure command to identify the part of the report you need. Here, picture box(1) captures the graph without the title for the entire section. Then, use JSL like this:
dt = Open( "$sample_data/big class.jmp" );
dist = dt << Distribution(
	Continuous Distribution( Column( :weight ) ),
	Nominal Distribution( Column( :age ) )
boxtree = Report( dist );
picbox = boxtree[Picture Box( 1 )];
picbox << savepicture( "$desktop/distrib.png", "png" );
The captured PNG fileThe captured PNG file
At the point when I had the picbox variable set, I was not sure what the command was to take a picture. I used this to find out what commands were available for that box:
showproperties(picbox)
and found this in the list:
save picture commandsave picture command
which you can then look up in the scripting index:
Help->Scripting IndexHelp->Scripting Index
jjswan33
	r = Column Dialog(
	st = dt <<
	Summary(
		Group(
			:Lot,
			:Wafer,
			Eval(splits)
	tb = Table Box();
			col = Column(st,i);
				tb << Append(
				tb << Append(
			tb
	Close(st, NoSave);
Sorry, I missed the data table bit. Data tables don't act like analysis platforms when trying to take pictures of their display boxes. Here's another approach, using a journal box.
dt = Open( "$sample_data/Cereal.jmp" );
journaltext = (Window( dt )) << getjournal;
journalbox = Journal Box( journaltext );
image = journalbox << getpicture;
New Window( "image", image );
pdf = journalbox << savepdf( "$temp/cereal.pdf" );
Open( "$temp/cereal.pdf" );
image capture of tableimage capture of table
You can save an image with
journalbox << savepicture( "$temp/cereal.png", "png" );
