- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Get Direct Link
Saved image DPI settings in JMP 17.0.0
I have been saving graphs as PNG images at higher than default DPI so that they can be resized cleanly in other programs like powerpoint. Recently I made the switch from JMP 16 to JMP 17 and the setting no longer seems to work -- is there some other setting now that governs saved image resolution? Here's an example: I saved the same plot with two different DPI settings and the resulting PNGs are identical.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Re: Saved image DPI settings in JMP 17.0.0
I suggest that you send this one to technical support (email: support@jmp.com).
Phil
- Mark as New
- Bookmark
- Subscribe
- Mute
- Get Direct Link
Thanks for posting this item! It has been seen by JMP Development, and i can confirm that there will be a fix for this in the next release of JMP, the next update to JMP 17.1, which will be available within a couple of months.
