blue1994
Save xlsx to csv file
anyone know how to save .xlsx to csv file with jsl? Is it possible to make it?
thanks.
Re: Save xlsx to csv file
names default to here(1);
dt=Open("path to the file.xlsx");
dt<<save as("path to new file.csv");
Details can be found at:
     Help==>Scripting Index==>Data Table==>Save As
Here is the example from the Scripting Index
dt << Save( "C:\Big Class.jmp" );
dt << Save( "C:\Big Class.csv" );
nikles
Hi @txnelson .  I'm curious if you happen to know of a method to convert an xlsx file to csv or text that does not require opening the xlsx as a JMP table first.  I have a few reasons, but the biggest reason is speed.  I've found that I can open a csv as a text string and perform a lot of preprocessing on it before creating the jmp table.  This seems to greatly improve speed, especially when opening multiple dozens of files at once.  My thinking is if I could convert excel tables to csv first, I could use the same script that I already use for opening our csv files into JMP.
I've been looking at the possibility of incorporating a python script into my jsl script, but I'm reluctant to require users to have the right python version and libraries on their machines.  Would be nice if there were a way to do it directly.
Any thoughts on this are greatly appreciated.  Thanks.
There may be a 3rd party shareware product out there that converts xlsx to csv, but there is nothing in native JMP to do that without reading it in as a JMP file first.
nikles
Got it. Thanks Jim.
