twaintwist
Save small datatable to Journal
I've been at this for a while and I know it's doable but I can't seem to get it to work....
I can save my Graphs to a journal but can't append a small data table (summary table) to the journal.....  --- any hints?
thechadd
Re: Save small datatable to Journal
Highlight the cells you want in the table, or select everything, then hit Crtl-J or Edit--> Journal.  The selected cells should show up in the Journal with column headers.
twaintwist
Thanks ---- I should have been more clear in my need ---- I need to save the Datatable to a journal using a script....
ms
Super User ms
dt = Open( "$ENGLISH_SAMPLE_DATA/Big Class.jmp" ) << Summary( Group( :Age ), Mean( :Height ) );
dt << journal;
Works in JMP 9 & 10, possibly also in older versions.
Heidi
Your solution works. However do you know a way to give that journal a name then I can append other graphs in the same journal?
xx = New Window( "my journal", <<journal );
dt << journal;
This is all covered in the Scripting Guide.  I strongly encourage you to read through it
     Help==>Books==>Scripting Guide
Article Labels
