See how to use JMP Live to centralize and share reports within groups. Webinar with Q&A April 4, 2pm ET.
SMTP setup
Ken_K
Is it possible to setup a SMTP server to send email through SMTP relay using JSL?   See some options on SAS but not sure how to setup using JSL.  Thank you
21 REPLIES 21
ian_jmp
Level X
Re: SMTP setup
Take a look at the 'Mail()' command.
Ken_K
Re: SMTP setup
Thank you for the reply.   When I use Mail() function the email is sent through outlook client which blocks automatic email sending for me.   I'm trying to use SMTP routing to avoid using outlook client.   Is there a way to configure mail() function to use SMTP routing instead of Outlook client?
ian_jmp
Level X
Re: SMTP setup
Understood. Maybe there is some help in this earlier thread.
ih
Super User (Alumni) ih
Re: SMTP setup
If you are on windows here an option using powershell:
commands = {
	"Send-MailMessage -From 'email@address' -To 'email@address' -Subject 'Test mail' -Body 'Message goes here' -SmtpServer smtp.server.com\!n",
	"exit\!n"
icommand = 0;
RP = Run Program(
	Executable( "PowerShell.exe" ),
	ReadFunction( Function( {this}, Write( this << Read ) ) ),
	WriteFunction(
		Function( {this},
			icommand++;
			If( icommand <= N Items( commands ),
				this << Write( commands[icommand] );
				this << WriteEOF;
Info about the powershell utility:
https://docs.microsoft.com/en-us/powershell/module/microsoft.powershell.utility/send-mailmessage?vie...
Note that this requires powershell version 2:
https://docs.microsoft.com/en-us/powershell/scripting/windows-powershell/starting-the-windows-powers...
hcarr01
Re: SMTP setup
Bonjour,
Comment je peux faire pour rajouter une pièce-jointe dans le mail svp ?
Re: SMTP setup
You can with most likely with all the different methods. For PowerShell (which I most of the time use) see the Microsoft documentation.
hcarr01
Re: SMTP setup
J’ai essayé avec la fonction « -Attachment » en suivant le modèle de ce lien :
En indiquant le bon chemin d’accès, je ne reçois pas de mail. Je dois faire une mauvaise manipulation ou utiliser une mauvaise syntaxe.
avez-vous un exemple de script faisant appel à une pièce-jointe SVP ?
ih
Re: SMTP setup
I just tried adding this to the end of the string in my example above and it worked:
 -Attachments 'C:/file.txt'
The complete example would be:
commands = {
	"Send-MailMessage -From 'email@address' -To 'email@address' -Subject 'Test mail' -Body 'Message goes here' -SmtpServer smtp.server.com -Attachments 'C:/file.txt'\!n",
	"exit\!n"
icommand = 0;
RP = Run Program(
	WriteFunction(
		Function( {this},
			icommand++;
				this << WriteEOF;
hcarr01
Re: SMTP setup
I managed to make it work for a path without particular characters (Example: "è", "é"...)
Is there a special function for using special characters in messages and paths?
undefined
I get this error message in the registry
I added a line to modify the encoding type in PowerShell but this does not solve the problem:
undefined
undefined
I'm also trying to skip lines in the body of my email, I tried with different methods like "\n"... but it doesn't work.
This post originally written in French and has been translated for your convenience. When you reply, it will also be translated back to French .
