i2-k
SEM / Path diagram
How do I edit the text boxes in path diagram? My latent variable is being truncated.  How do I resize the size of the text boxes on output for Path diagram.
Re: SEM / Path diagram
I'm not familiar with this platform, but have you tried if Customize Diagram Appearance does anything?
You should be able to at least increase the Latent variable shape width (and height) which might help
LauraCS
@i2-k , you can also access the "Customize Diagram" menu using the Diagram settings button:
As @jthi indicated, you can select Latent in the dropdown menu under Variable Appearance and then customize the width and height.
Laura C-S
