Discovery Summit 2026: Early User Edition - September 23-24.Register. It's free.
The proportional hazards model in JMP reports the ratio as a "risk ratio". How is this different from a "hazard ratio" and why does JMP report the risk ratio instead of the hazard ratio?
The risk ratio calculated by JMP’s Fit Proportional Hazards is the ratio of hazard rates. It measures the relative risks. You can refer to risk ratio as hazard ratio.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '9077' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '9077') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '9077') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
