Many ways of doing this. Do you need formula, is setting values enough, JSL or not, interactive solution?
Here is one possible formula, but I would remove it after it has been calculated once, as it won't re-evaluate in similar manner as formulas usually do (this might not be a problem in this case thou).
If(N Items(Loc(Current Data Table()[Row(), 1::N Cols()], "hello")) > 0,
"FALSE"
"TRUE"
This script should give a little extra explanation, it won't create new column for you though. Open log and run this, you can also change Row() = 1 to Row() = 2 and so on, to see how it behaves on different rows
dt = New Table("Untitled 9",
Add Rows(3),
New Column("Column 1", Character, "Nominal", Set Values({"hello", "bye", "bye"})),
New Column("Column 2", Character, "Nominal", Set Values({"hello", "bye", "bye"})),
New Column("Column 3", Character, "Nominal", Set Values({"hello", "bye", "bye"})),
New Column("Column 4", Character, "Nominal", Set Values({"hello", "hello", "bye"})),
New Column("Column 5", Character, "Nominal", Set Values({"hello", "bye", "bye"}), Set Display Width(75)),
New Column("Column 6", Character, "Nominal", Set Values({"hello", "bye", "bye"}))
Row() = 1;
Show(Current Data Table()[Row(), 1::N Cols()]);
Show(Loc(Current Data Table()[Row(), 1::N Cols()], "hello"));
Show(N Items(Loc(Current Data Table()[Row(), 1::N Cols()], "hello")));
Show(N Items(Loc(Current Data Table()[Row(), 1::N Cols()], "hello")) > 0);
Edit:
Removed extra "," from the formula
