Neo
Neo
Reset Text Edit Box to empty when rest button is pressed
I would like to reset the Text Edit Box to empty using the reset button in the script below. How to do this?
clear log ();
nw = New Window( "Get Data",
	<<Modal,
	<<Return Result,
	pid = Text Edit Box( "", <<Set Width( 160 ) ),
	Button Box ("Get ID & Data",
	ID = pid << get text;
	show (ID)),
	//getData (ID); run getData script. Get data script will go here.
	Button Box("Reset", /* Reset script to reset text edit box to empty*/),
	Button Box("Cancel", dialog("Cancelled by User"));
When it's too good to be true, it's neither
3 ACCEPTED SOLUTIONS
mmarchandTSI
Level V
Re: Reset Text Edit Box to empty when rest button is pressed
You can do this with the <<Set Text() message.
clear log ();
	<<Modal,
	<<Return Result,
	show (ID)),
	Button Box("Reset", pid << Set Text( "" ) ),
mmarchandTSI
Level V
lb << Remove All;
(My List Box is named lb)
I found this using
Show Properties( lb )
It's very helpful in situations like this.
You can disable display boxes using << Enable(0) and set it to 1 when it can be modified and then use << Set Text Changed or << Set function with text edit box
win = New Window("Example",
	teb = Text Edit Box("", << Set Text Changed(function({this, value},
		btn << Enable(!IsMissing(value));
	btn = Button Box("OK", << Enable(0))
12 REPLIES 12
mmarchandTSI
Level V
clear log ();
	<<Modal,
	<<Return Result,
	show (ID)),
Neo
Neo
@mmarchandTSI That is simple. Thanks. While, we are here, How would one reset a List Box if it was populated with a list of items?
mmarchandTSI
Level V
As in clear the selection in the list box or clear the items leaving none to select?  If you'd like to know what messages any certain display box can take, try
Show Properties( diplayboxname )
Neo
Neo
@mmarchandTSI  needs to be clear the items leaving none to select.
(Sorry should have been more specific in my last post)
mmarchandTSI
Level V
lb << Remove All;
I found this using
Neo
Neo
Show Properties ()
 is one of the best piece of advice I have received here. Many thanks.
Neo
Neo
<< Remove All () does empty the list.
hogi
Level XIII
This should work:
New Window( "Example",
	lb =
	List Box(
		{"First Item", "Second Item", "Third Item"},
		max selected( 2 ),
lb << Set Selected( 2 );
lb << Set Selected( 3 );
selected items = (lb << Get Selected Indices);
for each({index},selected items, lb<<  set selected (index, 0) )
Remove All
Clear Selection
In this case (definitely not always the case) both are documented in scripting index with working examples (remove all example is quite clunky as it doesn't use wait to let user see what it does).
Easiest way (in my opinion) to find these is to search for ListBox and then from "Item name matches" try different List Box options AND check from left side until you get the correct object (in this case it is ListBoxBox, you might have to do this by trial and error and experience of using scripting index).
After you have the correct object clicked, CLEAR your search text and press enter. You end up with the messages related to that object
It does take some time to learn, how to use, scripting index in different ways of searching for information (it is worth it if you do JMP scripting).
