ALopez
Rename columns using an associative array
Hi, I am trying to use an associative array to rename a bunch of columns. I have been using the Big Class data as an example. I will appreciate some help fixing my script.
dt = Data Table ("Big Class.jmp");
//Use and array to rename the Big Class table columns to "spanish"
newColNames = Associative Array();
newColNames["name"] = "nombre";
newColNames["age"] = "edad";
newColNames["sex"] = "sexo";
newColNames["height"] = "altura";
newColNames["weight"] = "peso";
uno = newColNames << Get Keys(); //for testing
newN = newColNames << Get Values({"name"}); //for testing
oriNames = dt << Get Column Names(); // in case there are variation on the number/name of columns
For( i=1, 1 <= N Items(oriNames), i++,
key = oriNames[i];
	Column(dt, key ) << set name (newColNames<<Get Values ({key}));
ian_jmp
Level X
Re: Rename columns using an associative array
You were very close:
oriNames = dt << Get Column Names("String"); 	// in case there are variation on the number/name of columns
For( i=1, i <= N Items(oriNames), i++,
	key = oriNames[i];
	Column(dt, key ) << set name ( newColNames << Get Value (key) );
ian_jmp
Level X
	key = oriNames[i];
@ian_jmp Took me way too long to see the "1"!
dt = Open( "$sample_data/Big Class.jmp" );
newN = newColNames << Get Values( {"age"} ); //for testing
oriNames = dt << Get Column Names( "string" ); // in case there are variation on the number/name of columns
For( i = 1, i <= N Items( oriNames ), i++,
	key = oriNames[i];
	Column( dt, key ) << set name( newColNames[key] );
ALopez
@ian_jmp
Thank you very much for you help. Important lessons: check you i's and "Get Values" and "Get Value".
Best regards,
AL
