UserID16644
Level V
Rename column Max(Max(date))
How to rename column Max(Max(date)) to "date"?
I tried:
1. :Max(Max(date)) << Set Name ("date");
2. :Name (Max(Max(date)) ) << Set Name ("date");
3. Column( dt, Max(Max(date))) << Set Name( "date" );
3. Column( dt, :Name (Max(Max(date))) ) << Set Name( "date" );
But none of these works
Thierry_S
Re: Rename column Max(Max(date))
When your column name has parentheses or any other special characters, your best bet is the following syntax:
Column (dt, "Max(Max(date))" << Set name ("date");
Note the quotes before and after the column name.
Best
TS
Thierry R. Sornasse
Thierry_S
Best
TS
Thierry R. Sornasse
I like using same syntax as @Thierry_S suggest (Column(dt_ref, "colname")) but if you want to use the colon syntax
:"Max(Max(date))" or even better would be :"Max(Max(date))"n. Using Name() is deprecated syntax for ""n. For some additional information regarding names see Names and JSL Rules for Names .
