UserID16644
Level V
How to get date yesterday?
I would want to get the date yesterday, I am using the today () function
dateNow = Format (Today(), "m/d/y");
However, I don't know how to derive from dateNow the date yesterday. Tried using d = (dateNow - 1);
but is not working.
hcarr01
Re: How to get date yesterday?
Dans ta table de données, tu peux créer une nouvelle colonne par exemple « date hier ».
dt=current data table();
// Nouvelle colonne : date hier dt << New Column( "date hier", Numeric, "Continuous", Format( "Best", 12 ), );
et ensuite tu peux écrire cette formule avec la date que tu souhaites obtenir.
// Modifier la formule de colonne : date hier
dt:date hier << Set Formula( Date MDY( 7, 25, 2023 ) );
en sortie tu obtiens ceci :
You will have to deduct the seconds in one day from Today(), using In Days(1) is one option (you could also use 24*60*60)
Today() - In Days(1)
Datetime values are handled internally as numbers of seconds since midnight, January 1, 1904 (JSL Syntax Reference > JSL Functions, Operators, and Messages > Date and Time Functions )
