syedhashmi
Removing embedded spec limits from columns
Hi, I have jmp data coming from ATE and the columns have embedded spec limits, which sometimes make the data analysis difficult (limits are wide, so outliers are hiding etc)...I can remove the embedded limits one by one by going to column properties, but i am looking for a way to remove limits from multiple columns at the same time..
please suggest a way...
thanks.
Re: Removing embedded spec limits from columns
select all of the columns you are interested in, and then go to
     cols==>Standardize attributes
You will be able to remove all of them at once
syedhashmi
Thanks. This worked. appreciate the help.
