uProf
Remove percentage sign in Graph Builder
Hi -
I am interested in removing redundant % sign in the graph generated with graph builder since Y axis already has it. This would help with space when I have too many bars.
How can I remove percentage sign that is highlighted in red?
I am using Jmp 12.2
Thank you!
ian_jmp
Level X
Re: Remove percentage sign in Graph Builder
Sorry, I don't have that version to hand. But, if it helps, in the current version theres an option:
Level XIII
@ian_jmp
Doesn't the screenshot shows how to remove the label?
How to remove the percentage sign of the label in the current Jmp version?
The only way that I think you can do what you want is to add the labels by writing some simple JSL.
dt << New Column( "percent", Format( "percent", 12, 1 ), formula( :Height / :Weight ) );
gb = Graph Builder(
	Size( 528, 448 ),
	Variables( X( :sex ), Y( :percent ) ),
	Elements( Bar( X, Y, Legend( 6 ) ) )
gbr = gb << report;
flist = {.0};
Insert Into( flist, Round( Col Mean( If( :sex == "F", :percent, . ) ), 3 ) );
f = Char( flist[2] * 100 );
mlist = {1};
Insert Into( mlist, Round( Col Mean( If( :sex == "M", :percent, . ) ), 3 ) );
m = Char( mlist[2] * 100 );
gbr[framebox( 1 )] << Add Graphics Script(
	Text( Center Justified, flist, f );
	Text( Center Justified, mlist, m );
Here is a solution for newer versions of JMP
We can start with the same example as the previous post
gb = Graph Builder(
	Size( 528, 448 ),
Then in Graph Builder choose Label -> Label By Value.  This will show the extra % symbol
Under Label Format, click on the Auto dropdown (twice) and choose a new format.  One option would be best or fixed dec, but this will show the format as a decimal value
To get that value * 100, but without the percent symbol click on the dropdown again and choose Custom
Click Set Custom Format
The formula editor will open with the word value in the middle.  Click the multiplication button and then type 100
Click OK
