UserID16644
Remove character strings
I have this column SAMPLE where I need only to retain the code inside the () but somehow, I cannot remove the Column% word and the parenthesis. I tried using Word(2,:SAMPLE) but it only returned an error.
How to remove the word Column % and the parenthesis from the string?
Re: Remove character strings
Using Word seems to work fine for me
dt = New Table("Untitled 18",
	Add Rows(1),
	Compress File When Saved(1),
	New Column("S", Character, "Nominal", Set Values({"COLUMN %(AC353)"}))
dt << New Column("", Character, Nominal, Formula(
	Word(2, :S)
Could you provide the datatable instead of an image? Also changing the separator to () instead of " " (default) might work
	Word(2, :S, "()")
	Add Rows(1),
	Word(2, :S)
	Word(2, :S, "()")
UserID16644
Attached file is the sample data table. What I want is that only AC353, AEE67 and so on would be the only values of the column sample.
Formula I provided with "()" should work, just replace :S with correct column
