BookmarkSubscribeRSS Feed
albert419870
Community Trekker
Dec 24, 2015
Read JMP variable value in SAS?
Currently I've written some SAS codes in enterprise guide (SAS ver: 9.3), and I also want to combine functions in JMP then read out JMP variable value in SAS.
Is there any fast way to read JMP variable from SAS?
So far I think I can call JMP script to execute from SAS, then put variable in a JMP / SAS table. And finally use SAS to import the table to get the value.
But I thought it contains too much procedures and file processing...so I'm searching if other better way for it.
Also I checked JMP scripting guide "Working with SAS" chapter, however, I guess it's just mentioned about how to use SAS capability within JSL.
Please also correct me if my guess is wrong.
Thanks all for your reading!
Jun 22, 2012
Solution
Re: Read JMP variable value in SAS?
I am not aware of a method where a JMP memory variable can be made available for a direct read into SAS, however, an alternative to placing a value into a JMP data table and then reading it into SAS, in JMP you could easily create a text file that contains SAS code, and then simply do a %include in SAS to populate those values.
x=32;  // hypothetical JMP value you want to transfer to SAS
save text file("C:\file.txt","%let x="||char(eval(x))||';");
then in your SAS program, just use a %include statement to include the file you just created.
Jun 22, 2012
Solution
Jeff_Perkinson
Community Manager
Jun 23, 2011
Take a look at the DeclareMacros() option on the SAS Submit() statement.
It will automatically create a SAS macro variable with the same name and value as a JSL variable.
-Jeff
-Jeff
