Cartica
ROC curve, probability , cut off
How do I find the cut off value from the probaility on the ROC. I had to adjust to get a better AUC. Thanks
Re: ROC curve, probability , cut off
Which a analysis platform are you using?
Do you see an outline for the ROC details? If so, it contains the probabilities.
The AUC does not depend on the a cutoff.
