aberquin
ROC AUC confidence interval
Is it possible to calculate the 95% confidence interval of a ROC AUC ?
I found a add-in that was supposed to to so but does not seem to work for this option:
Thanks for your help,
Anne
KarenC
Re: ROC AUC confidence interval
Hi Anne,
That was an add-in I had created...I have kept this one running over the years (IVD performance ) but not the one with the AUC confidence intervals. Now I tend to use bootstrap CI in JMP Pro.  Without pro you could build your self a calculator table using column formulas to calculate your interval - there is more than one way to get at the confidence intervals so you would need to decide on the method.
This add-in has the AUC and more (Threshold Explorer).
However that may be more than what you need and can be slow to run.
Karen
KarenC
Hi Anne,
Karen
