AlexS
REGEX HELP with White Spaces
Hello
I can do what i want for regex in an editor but I'm having trouble switching it over to use for JMP.
The following does what i need it do to in the editor
([E]|[e])[2]|(231)
i can't seem to get to work exactly like i need it to in JMP i got as far as the below
Regex( :TEXT, "(E2|e2|231\d?)", "\1" )
it will pick up E2 or e2 no problem but for 231 i need it to only extract when there is whitespace either side of it.
I have been looking through the community but can't find exactly what I need.
In an ideal world it will display all results in the column not just one?
I'm sure someone out there can tell me seconds how to do it
Alex is the name, Power BI/ SQL /JMP is my game
gzmorgan0
Re: REGEX HELP with White Spaces
@AlexS ,
Mark, @Mark_Bailey , provided you with the pattern to find any number in the first pattern  "space + any number + space"
Maybe I misread your response but it seemed  to me you were looking for the specific sequence  space + 231 + space.
If yes, an alternative solution is to use the Contains() function. The code is a little more readable. Note REGEX returns a string, so if you want the number you need the Num() function. A table with both functions is attached to this post.
If( Contains( :Text, " 231 " ),
	231
Here is a formula that should work to get what you want.  The column you apply this to, needs to be a Character Column.
If( Row() == 1,
	getValues = Function( {},
		returnVal = "";
			returnVal = "321"
		If( Contains( :Text, " e2 " ),
			If( returnVal != "",
				returnVal = returnVal || ", "
			returnVal = returnVal || "e2";
		If( Contains( :Text, " E2 " ),
			returnVal = returnVal || "E2";
		returnVal;
theValue = getValues();
gzmorgan0
@AlexS ,
\s is usually the symbol for white space or \sb. However, it will be easier to give your a response if you provide an example of one row of column :text and what you are trying to extract, Make something up if it is proprietary.
AlexS
@gzmorgan()
So example text would be
Jsjsjjs 231 jdjdjdj 2377474742311
I don’t want it from the second numeric sequence just when there is white space either side at the moment it would pick up 2311 when all I want is 231 if there is one
Thank you
This example shows the expression to get the second part of your target based on the example that you provided.
Regex(
	"Jsjsjjs 231 jdjdjdj 2377474742311",
	"\s(\d+)\s",
	"\1"
gzmorgan0
@AlexS ,
	231
AlexS
@gzmorgan0,
Both will be required in some form but specifically to this request I need it for ‘231’ so thanks to both of you.
How would I get it to search for all 3 and then put it all in one column if it’s there? Is it just a case of creating multiple Regex along with concatenation of columns?
So for example I am looking for E2 or e2 or 231 but it will return one of those only. What I’d like is for it to return everything it finds?
Thank you for your direction and help
If( Row() == 1,
		returnVal = "";
			returnVal = "321"
		returnVal;
AlexS
Excellent thank you for your time.
