RonB
Graph Builder commulative counts of events
How to make simple line graph of commutative occurrences of events month to month? ie month2 = monthe1+month2 etc.
thanks
Re: Graph Builder commulative counts of events
Sorry......to do the counts, just change the statistic to N in the Summary()gender.PNGgender.PNG
names default to here(1);
dt=Open("$SAMPLE_DATA/big class.jmp");
// Summarize the data
dtSum = dt << Summary(
	Group( :age ),
	N( :sex ),
	Freq( "None" ),
	Weight( "None" )
// Create the cummulative sum column
dtSum << New Column("Gender Cumulative Count", formula( Col Cumulative Sum( :Name( "N(Sex)" ) )));
// Generate the graph
dtSum << Graph Builder(
	Size( 534, 450 ),
	Show Control Panel( 0 ),
	Variables( X( :age ), Y( :Gender Cumulative Count ) ),
	Elements( Bar( X, Y, Legend( 6 ) ) )
Others may have an easier way, but this is how I would do it
  1. Use Tables==>Summary to sum the measurement column(s)  for each of the X axis groups.
  2. Create a new column in the summary table which is the Col Cumulative Sum() of the summarized measurement column(s)
  3. Graph the data
Very easy to do interactively.  But here is the script that produced the above graph
	Group( :age ),
	Sum( :height ),
	Freq( "None" ),
	Weight( "None" )
dtSum << New Column("Height Cumulative Sum", formula( Col Cumulative Sum( :Name( "Sum(height)" ) )));
	Size( 534, 450 ),
	Variables( X( :age ), Y( :Height Cumulative Sum ) ),
RonB
Thanks. I knew  how to do it with continuous var. I asked about commutative counts, month1 has 2 events, month2 has 5, month3 has 1, so  I'll show 2-7-8.
	Group( :age ),
	N( :sex ),
	Freq( "None" ),
	Weight( "None" )
	Size( 534, 450 ),
