Question on one way analysis
My goal: Generate 100 different box plots using ENT on the X axis and various other parameter's on Y axis.
I have a table with 100 continuous variables like height and weight from Big class.jmp.
I would like to create a for loop with "i" index sweeping from 1 to 100 and execute the following statement 100 times to print out box plots.
p= Oneway( Y( :list1 ),    X( :ENT ) );
For some reason oneway is not able to take list1 as it's input.
What is the best way to create multiple box plots using recursive functions?
Thanks for your help[,
C
ms
Super User ms
Re: Question on one way analysis
Try without the scoping operator
p= Oneway( Y( list1 ),    X( :ENT ) );
list1 = dt << get column names(numeric);
For(i = 1, i <= N Items(list1), i++,
    p = Oneway(Y(list1[i]), X(:age))
