JunepyoOh
Question about Kaplan Meier survival curves.
Hello, I'm very new to JMP software. I'm trying to generate Kaplan Meier survival curve for my research.
So far, I made my data set like this (If I made a mistake about the below table for Kaplan Meier, let me know):
Time (day)DiedCencor
000
12.670
220
310
40.330
500
5241
After that, I used the Survival platform (Y=months, Censor=censor, and Freq=died). The result started with day 1. But I want to get this result starting with 0 day (I think it will give me 100% survival between day 0 ~ 1). Here is my current result and thank you for any helps from you.
peng_liu
Re: Question about Kaplan Meier survival curves.
Have you tried to "drag" the x-axis? That is part of the rich interactivity features of JMP. By "drag", I mean the following:
Hover the mouse at the highlighted spot as in the following screenshot. When you see a hand icon pointing to the left, do next step.
Click left mouse button and hold it, don't let it go. Then drag to right, until you see 0 on the axis. Now you can let the button go.
The following screenshot is what I got after that.
